SDRplay ExtIO error when starting Duo
I get the error shown below often when starting my Duo on HDSDR (the first instance). If I turn off my PC and restart it sometimes it will fix the problem. Some times I have to turn off/on my PC several times to fix the problem. Is there an easier way?
Windows 10 Pro
thanks, Jay K0GU
Windows 10 Pro
thanks, Jay K0GU
- ExtIOError.jpg (5.92 KiB) Viewed 66758 times
Last edited by coloradojay2 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Re: SDRplay ExtIO error when starting Duo
What happens when you run the RSPduo in Dual Tuner mode with two instances of SDRuno? Do you receive any API error pop-ups?
Selected the appropriate extio dll's and did not encounter a problem can you more more specific on your set up?
