HDSDR & SDRuno on one PC?
I am curious if I can install SDRuno and HDSDR on the same Laptop PC? I like SDRUno for shortwave and FM Broadcast but HDSDR for other reception.
Re: HDSDR & SDRuno on one PC?
I have them both installed on my laptop and they both work fine with my RSP2.
Yes, you sure can
. I'm using HDSDR, SDRUno, & SDRSharp all on the same computer for different purposes and they all work fine. But of course you can use only one of them at a time.....
Before SDRuno version 1.12 you could have SDRuno, HDSDR and SDR# all loaded at the same time and just switch windows without having to close and reload each of them as long as only one was streaming at a time. It's quite convenient to not have to keep reloading SDRuno all the time as it always looses so much of it's state that has to be reentered each time it's loaded.
This is detailed in this post, along with the bad design reasons for the new issues...
http://sdrplay.com/community/viewtopic.php?f=11&t=2029
Tnanks. I bave SDRuno 1.13, HDSDR 2.76 and
SDR'Condole versio. 3.. Each works for me. In difgerent areas
