// Tuner_Knob_Trinket
// Based on Adafruit Volume Control
https://learn.adafruit.com/trinket-usb-volume-knob
// and work by Mike KD2KOG
// Modified by GM4CID 2016-09-12
#include "TrinketMouse.h"
#define PIN_ENCODER_A 0
#define PIN_ENCODER_B 2
#define TRINKET_PINx PINB
static uint8_t enc_prev_pos = 0;
static uint8_t enc_flags = 0;
void setup()
// set pins as input with internal pull-up resistors enabled
pinMode(PIN_ENCODER_A, INPUT);
pinMode(PIN_ENCODER_B, INPUT);
digitalWrite(PIN_ENCODER_A, HIGH);
digitalWrite(PIN_ENCODER_B, HIGH);
TrinketMouse.begin(); // start the USB device engine and enumerate
// get an initial reading on the encoder pins
if (digitalRead(PIN_ENCODER_A) == LOW) {
enc_prev_pos |= (1 << 0);
if (digitalRead(PIN_ENCODER_B) == LOW) {
enc_prev_pos |= (1 << 1);
void loop()
int8_t enc_action = 0; // 1 or -1 if moved, sign is direction
// note: for better performance, the code will now use
// direct port access techniques
http://www.arduino.cc/en/Reference/PortManipulation
uint8_t enc_cur_pos = 0;
// read in the encoder state first
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER_A)) {
enc_cur_pos |= (1 << 0);
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER_B)) {
enc_cur_pos |= (1 << 1);
// if any rotation at all
if (enc_cur_pos != enc_prev_pos)
if (enc_prev_pos == 0x00)
// this is the first edge
if (enc_cur_pos == 0x01) {
enc_flags |= (1 << 0);
else if (enc_cur_pos == 0x02) {
enc_flags |= (1 << 1);
if (enc_cur_pos == 0x03)
// this is when the encoder is in the middle of a "step"
enc_flags |= (1 << 4);
else if (enc_cur_pos == 0x00)
// this is the final edge
if (enc_prev_pos == 0x02) {
enc_flags |= (1 << 2);
else if (enc_prev_pos == 0x01) {
enc_flags |= (1 << 3);
// check the first and last edge
// or maybe one edge is missing, if missing then require the middle state
// this will reject bounces and false movements
if (bit_is_set(enc_flags, 0) && (bit_is_set(enc_flags, 2) || bit_is_set(enc_flags, 4))) {
enc_action = 1;
else if (bit_is_set(enc_flags, 2) && (bit_is_set(enc_flags, 0) || bit_is_set(enc_flags, 4))) {
enc_action = 1;
else if (bit_is_set(enc_flags, 1) && (bit_is_set(enc_flags, 3) || bit_is_set(enc_flags, 4))) {
enc_action = -1;
else if (bit_is_set(enc_flags, 3) && (bit_is_set(enc_flags, 1) || bit_is_set(enc_flags, 4))) {
enc_action = -1;
enc_flags = 0; // reset for next time
enc_prev_pos = enc_cur_pos;
if (enc_action > 0) {
TrinketMouse.move(0,0,1,0);
else if (enc_action < 0) {
TrinketMouse.move(0,0,-1,0);
// else {
// TrinketMouse.poll(); // do nothing, check if USB needs anything done
