SDRPlay / FM SCA decoding
Posted: Mon Sep 05, 2016 10:01 pm
I am an old hand at 'radio' but SDRs are new to me so bear with me on this please!
I have a 'local' FM that uses a 67 kHz SCA and tried to decode that using SDRPlay and the 'included' CubicSDR (OSX) and it appears there is not sufficient 'separation' from the main FM modulation to allow the decode to work.
I tried turning off the AGC and playing with the levels manually (What exactly is the difference between LNAT -- and what the heck is that!?) and 'tuner' gain?) but alas, no joy. I also played with the IF options and none appeared to make a difference.
Am I doing something wrong, or is this Beta iteration not 'good enough' to separate the SCA from the main modulation and in need of 'updating'?
And why oh WHY is it so hard to get software with all the appropriate 'hooks' installed so it 'just works'? I was VERY pleased with how easy it was to get the SDRPlay to work with CubicSDR on MacOSX (kudos to whoever did this! You 'get' it!) but I'd like to try other software packages too. I mean, they're out there, but (for example) I can't get ''gqrx' to recognize the SDRplay is attached to the USB port, and I gather I need to know how to compile things to do this, because the software doesn't actually have all the 'bits' needed to 'address' the USB port, or something like that. Hey, I am a radio geek not a computer geek! I have similar issues with DREam software too. It is like the computer zoomies want to make us feel inadequate!
Thanks for whatever help you can offer! 73.
