Using SDRPlay with WSPR beacon project
Posted: Mon Nov 07, 2016 12:24 pm
Hi all,
I'm using the SDRPlay with the WSJT-X program by Joe Taylor K1JT to monitor band conditions. I've used a variety of programs to get the audio including the excellent SDR Console by Simon Brown. I can tune the SDR to the required frequency and get WSJT-X to decode the signals. There are 2 things that I cannot get to work - indeed I don't know if they are actually possible.
1) I would like to be able to "hear" 3 different frequencies at the same time and decode them. I have 3 receivers set up in SDR Console but can only get the audio from 1 at a time. When I switch between the receivers I can see that each one is going to a separate instance of WSJT-X and they each decode well. I have downloaded VB-Virtual audio cables to allow this.
2) I would like to get WSJT-X to change the frequency of the receiver. Connected to Ham Radio Deluxe using the demo, I can see the frequency changes in HRD. My problem is that, no matter what I do, I can't get the SDRPlay (using SDR Console) to change frequency. If I could do this I could frequency hop from WSJT-X
Any help will be gratefully appreciated even if it's a can't be done
Many thanks Colin
Many thanks Colin
