HDSDR w/RSP2 to HRD to a FTDX3000
Posted: Thu Mar 02, 2017 3:19 am
Ok I am in need of little help here, I have my FTDX3000 hooked to my pc via USB, and HRD has always worked just fine, Now I connected my RSP2 and got HDSDR working just fine with the FTDX3000 via Omnirig. HRD is not running at this time.
The issue I am having is getting HDSDR to connect to HRD via DDE to Hrd. I am starting up the 3000, then HRD v6.3, then starting up HDSDR, I go to the HDSDR option, select DDE to HRD and everytime it says failed to connect
Am I missing a setting somewhere? Maybe something in Hrd's settings that's not turned on?
