Help with Calibration Console V3
Posted: Sat Nov 18, 2017 10:24 pm
by KO4XJ
I have a RSP2 I bought 2 months ago to use as a panadapter with a Ten Tec Orion 1 and I have the PAT board installed for the buffer amp.
After weeks trying to get SDRUno to work I gave up and have SDRConsole V3 working for what I want. But here's my issue(s)
To hear the same signal on the laptop and radio at the same freq I had to adjust the PPM on the Calibration screen but to get 40 and 80m to work I had to adjust -170ppm and for 15, 17 and 20m I had to adjust +490ppm.
Just to check with WWV at 5Mhz and 15Mhz I had to adjust +159.5 and +158.5ppm.
As you can see I'm all over the place and am I doing it wrong to calibrate?
Also I'm using 2048Khz as the bandwidth
Any help would appreciated
73
John
KO4XJ
