RSPduo & trunked radio systems
I just got my RSPduo a few days ago. I thought I would be able to use it as having two dongles running simultaneously to listen to one on a control channel and the other would listen to the voice channels. As it is when using two RTL-SDR dongles along with DSD+ and SDR#.
I've been able to get audio from SDRuno to DSD+ and decode it but I cannot figure out how to get the package of SDRuno and DSPduo to listen to a control channel and follow voice channels. If anyone else has experience in this area please let me know how to proceed.
Thanks.
Thanks.
Re: RSPduo & trunked radio systems
I'm interested in this as well. Seeing as how SDRPlay has an "API", one would think it should be easy to intergrate with other apps. I'm not a programmer though
If DSD+ can communicate via CAT, then SDRuno could be used that way - it will respond as per a Kenwood TS-480
Hope that helps,
Hope that helps,
