In the interest of extending my paltry knowledge base
Posted: Mon Jul 23, 2018 6:02 am
From a low starting point, I wold like to understand a few things, but starting with just one - When tuned to any particular area of the RF spectrum using the RSP, I often observe what appear to be sporadic/intermittent apparent surges in signal strength.
Increasing attenuation to it's maximum usually stops these surges, however, occasionally the opposite seems to apply and decreasing attenuation to minimum may also work.
Question #1: Is my assumption of cause correct?
Question #2: Is the phenomenin normal and if so, why would opposite amounts of attenuation have the same effect?
Question #3: Since I find that it is sometimes desirable to use the minimum amount of attenuation to listen to a particular signal and these surges are present, is it harmful to the RSP?
Thanks in advance for any offerings...
