Edit issue with first post in a thread
Nulluser00
Postby Nulluser00 » Sat Feb 23, 2019 1:00 pm
Even though I no longer participate in this forum, when I ran into an issue similar to the one this page experiences when one tries to edit their first post in a thread.
This solved the problem with the EE student help system.
I hope this helps
Noel
https://www.phpbb.com/community/viewtopic.php?t=2123804
Post Edit Issue after updating from 3.0.7 to 3.0.8
END OF SUPPORT: 1 January 2017 (announcement)
· 1
· mubasshar
Registered User
Post by mubasshar » Thu Mar 10, 2011 7:31 pm
after updating my board to 3.0.8 successfully i am unable to edit any post with out admin user name.
i am getting this error
You must enter at least two poll options.
any idea about the solution .......
Top
mubasshar
Registered User
Re: Post Edit Issue after updating from 3.0.7 to 3.0.8
Post by mubasshar » Thu Mar 10, 2011 7:34 pm
most probably when i am trying to edit someone other's post.
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Thu Mar 10, 2011 7:35 pm
Please fill out the Support Request Template Generator and post it back here to enable us to assist you better.
Top
mubasshar
Registered User
Post by mubasshar » Thu Mar 10, 2011 8:16 pm
What version of phpBB are you using? phpBB 3.0.8 RC1
What is your board's URL? www.pakdiscussion.com
Who do you host your board with? webhostingpad
How did you install your board? I used the download package from phpBB.com
Is your board a fresh install or a conversion? Update from a previous version of phpBB3
Do you have any MODs installed? Yes
Is registration required to reproduce this issue? Yes
What version of phpBB3 did you update from? phpBB 3.0.7
What MODs do you have installed? Thanks For Post
Related Topics
What styles do you currently have installed? Apple
What language(s) is your board currently using? English
Which database type/version are you using? MySQL 5
What is your level of experience? Comfortable with PHP and phpBB
What username can be used to view this issue? No answer given
What password can be used to view this issue? No answer given
When did your problem begin? after updating from 3.0.7 to 3.0.8
Please describe your problem. asking for poll option while editing someone other post. but same thing i can edit with admin.
Generated by SRT Generator ($Rev: 4778 $)
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Thu Mar 10, 2011 9:18 pm
Try switching your style to Prosilver and see if the issue persists.
What version of the apple style are you using? (see the style/apple/style.cfg file).
Top
mubasshar
Registered User
Post by mubasshar » Fri Mar 11, 2011 8:12 am
unfortunately i dont have the pro silver style installed. apple version is 3.0.5. and i am not facing this issue in 3.0.7 version. thanks for your support.
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Fri Mar 11, 2011 12:56 pm
If you are using phpBB3 version 3.0.8 you must update your style to the same version. Style and board versions now must match.
I suggest installing the Prosilver style as a temporary measure, it can be downloaded and extracted from the full version found here http://www.phpbb.com/downloads/olympus.php?from=submenu
Top
mubasshar
Registered User
Post by mubasshar » Fri Mar 11, 2011 6:18 pm
i will definately try out the suggestion but the only point is that why i can edit the same post with admin user if there is some issue with the template.
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Fri Mar 11, 2011 6:36 pm
It has some style dependencies.
Top
mubasshar
Registered User
Post by mubasshar » Sat Mar 12, 2011 3:42 pm
from where i can download prosilver . i tried to find the latest version for apple but did not find...
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Sat Mar 12, 2011 4:42 pm
Download the full package fro here http://www.phpbb.com/downloads/olympus.php?from=submenu
And extract Prosilver.
Top
mubasshar
Registered User
Post by mubasshar » Sun Mar 13, 2011 9:33 am
yup i created a test environment for php 8 and its working fine for all the templates even for apple 3.0.5. i am not facing the above mentioned issue in the new installation. than is it due to some mod can u please guide me on that.
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Sun Mar 13, 2011 11:35 am
In your test system the apple style 3.0.5 is not working correctly and will not.
Only thing I can suggest is a complete file replacement but you will lose all your MOD's.
Please follow exactly in in proper order'
*NOTE: Before proceeding backup all files and the database.*
· Upload all new files from a download of the full version, EXCEPT for config.php, the /images and /files folders.
· Go to yoursite.com/forumfolder/install/database_update.php
· Let that run and then delete the install folder.
· You now have a new up to date board containing all your users and posts but without any MODs that you might have had installed.
Top
mubasshar
Registered User
Post by mubasshar » Sun Mar 13, 2011 12:57 pm
so you mean i should not proceed with the apple any more .
Top
Pit$Bull
Former Team Member
Post by Pit$Bull » Sun Mar 13, 2011 7:15 pm
To use the apple style it will have to be updated manually, see http://www.phpbb.com/community/viewtopi ... 4&t=880735
Top
· 1
· Return to “[3.0.x] Support Forum”
