Missing the big picture
Re: Missing the big picture
Here's how I do it. I have created myself a small batch script...
#!/bin/csh
rm -rf CubicSDR
git clone https://github.com/cjcliffe/CubicSDR.git ./CubicSDR
cd CubicSDR
mkdir build
cd build
make ../ -DCMAKE_BUILD_TYPE=Release
make
then I run ./CubicSDR/build/x64/CubicSDR
I would do this in an empty directory so that you don't accidentally remove any existing directories.
Is it complaining about SoapySDR or another dependency? There is also a good group on the http://cubicsdr.com website to help with build issues. If SoapySDRUtil --probe=sdrplay is successful then at least you have the hardware side sorted out.
SDRplay
https://github.com/pothosware/SoapySDR/wiki/BuildGuide
Everything was good until the cmake step for SoapySDR - Doxygen and python3 bindings were missing, but I continued on until I got a final error in running SoapySDRUtil --info to check if everything was OK. You can see the whole mess below. Please tell me what I did wrong, and how to recover.
paul@sdr:~$ pwd
/home/paul
paul@sdr:~$ ls
Desktop Documents Downloads Music Pictures Public Templates Videos
paul@sdr:~$ mkdir sdr
paul@sdr:~$ cd sdr
paul@sdr:~/sdr$ ls ../Downloads/
SDRplay_RSP_MiricsAPI-1.9.4.run
paul@sdr:~/sdr$ cp ../Downloads/SDRplay_RSP_MiricsAPI-1.9.4.run .
paul@sdr:~/sdr$ ./SDRplay_RSP_MiricsAPI-1.9.4.run
bash: ./SDRplay_RSP_MiricsAPI-1.9.4.run: Permission denied
paul@sdr:~/sdr$ sudo ./SDRplay_RSP_MiricsAPI-1.9.4.run
[sudo] password for paul:
sudo: ./SDRplay_RSP_MiricsAPI-1.9.4.run: command not found
paul@sdr:~/sdr$ chmod 755 SDRplay_RSP_MiricsAPI-1.9.4.run
Verifying archive integrity... All good.
Uncompressing SDRplay Mirics API Install Package V1.9.4 100%
Installing SDRplay RSP Mirics API library...
Architecture: x86_64
API Version: 1.8.1
Remove old libraries...
Install /usr/local/lib/libmirsdrapi-rsp.so
Remove old header files...
Install /usr/local/include/mirsdrapi-rsp.h
Udev rules directory found, adding rules...
Libusb found, continuing...
Installing SoapySDRPlay...
Installing SoapySDR...
Finished.
paul@sdr:~/sdr$ pwd
/home/paul/sdr
paul@sdr:~/sdr$ ls
paul@sdr:~/sdr$ lsmod|grep msi
paul@sdr:~/sdr$ ls /etc/default
alsa apport console-setup cron dbus grub im-config keyboard networking ntp rsync ufw
anacron bsdmainutils crda cryptdisks devpts halt irqbalance locale nss rcS rsyslog useradd
paul@sdr:~/sdr$ ls /etc/modprobe.d
alsa-base.conf blacklist.conf blacklist-framebuffer.conf blacklist-oss.conf blacklist-watchdog.conf iwlwifi.conf mlx4.conf
blacklist-ath_pci.conf blacklist-firewire.conf blacklist-modem.conf blacklist-rare-network.conf fbdev-blacklist.conf libpisock9.conf vmwgfx-fbdev.conf
paul@sdr:~/sdr$ sudo nano /etc/modprobe.d/blacklist.conf
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$ sudo apt-get install \
> cmake g++ \
> libpython-dev python-numpy swig
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
binutils cmake-data g++-5 gcc gcc-5 libasan2 libatomic1 libblas-common libblas3 libc-dev-bin libc6-dev libcc1-0 libcilkrts5 libexpat1-dev libgcc-5-dev libgfortran3 libitm1
libjsoncpp0v5 liblapack3 liblsan0 libmpx0 libpython2.7-dev libstdc++-5-dev libtsan0 libubsan0 linux-libc-dev make manpages-dev swig2.0
Suggested packages:
binutils-doc codeblocks eclipse ninja-build g++-multilib g++-5-multilib gcc-5-doc libstdc++6-5-dbg gcc-multilib autoconf automake libtool flex bison gdb gcc-doc
gcc-5-multilib gcc-5-locales libgcc1-dbg libgomp1-dbg libitm1-dbg libatomic1-dbg libasan2-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg libcilkrts5-dbg libmpx0-dbg
libquadmath0-dbg glibc-doc libstdc++-5-doc make-doc gfortran python-dev python-nose python-numpy-dbg python-numpy-doc swig-doc swig-examples swig2.0-examples swig2.0-doc
The following NEW packages will be installed:
binutils cmake cmake-data g++ g++-5 gcc gcc-5 libasan2 libatomic1 libblas-common libblas3 libc-dev-bin libc6-dev libcc1-0 libcilkrts5 libexpat1-dev libgcc-5-dev libgfortran3
libitm1 libjsoncpp0v5 liblapack3 liblsan0 libmpx0 libpython-dev libpython2.7-dev libstdc++-5-dev libtsan0 libubsan0 linux-libc-dev make manpages-dev python-numpy swig
swig2.0
0 upgraded, 34 newly installed, 0 to remove and 1 not upgraded.
Need to get 69.9 MB of archives.
After this operation, 200 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://us.archive.ubuntu.com/ubuntu/ wily/main cmake-data all 3.2.2-2ubuntu3 [1,029 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ wily/main libjsoncpp0v5 amd64 0.10.5-1 [74.2 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ wily/main cmake amd64 3.2.2-2ubuntu3 [2,536 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu/ wily-updates/main binutils amd64 2.25.1-6ubuntu2 [2,281 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu/ wily/main libcc1-0 amd64 5.2.1-22ubuntu2 [31.0 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu/ wily/main libitm1 amd64 5.2.1-22ubuntu2 [27.4 kB]
Get:7 http://us.archive.ubuntu.com/ubuntu/ wily/main libatomic1 amd64 5.2.1-22ubuntu2 [8,950 B]
Get:8 http://us.archive.ubuntu.com/ubuntu/ wily/main libasan2 amd64 5.2.1-22ubuntu2 [269 kB]
Get:9 http://us.archive.ubuntu.com/ubuntu/ wily/main liblsan0 amd64 5.2.1-22ubuntu2 [110 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu/ wily/main libtsan0 amd64 5.2.1-22ubuntu2 [249 kB]
Get:11 http://us.archive.ubuntu.com/ubuntu/ wily/main libubsan0 amd64 5.2.1-22ubuntu2 [100 kB]
Get:12 http://us.archive.ubuntu.com/ubuntu/ wily/main libcilkrts5 amd64 5.2.1-22ubuntu2 [40.0 kB]
Get:13 http://us.archive.ubuntu.com/ubuntu/ wily/main libmpx0 amd64 5.2.1-22ubuntu2 [9,822 B]
Get:14 http://us.archive.ubuntu.com/ubuntu/ wily/main libgcc-5-dev amd64 5.2.1-22ubuntu2 [2,228 kB]
Get:15 http://us.archive.ubuntu.com/ubuntu/ wily/main gcc-5 amd64 5.2.1-22ubuntu2 [6,708 kB]
Get:16 http://us.archive.ubuntu.com/ubuntu/ wily/main gcc amd64 4:5.2.1-3ubuntu1 [5,204 B]
Get:17 http://us.archive.ubuntu.com/ubuntu/ wily-updates/main libc-dev-bin amd64 2.21-0ubuntu4.1 [68.6 kB]
Get:18 http://us.archive.ubuntu.com/ubuntu/ wily-updates/main linux-libc-dev amd64 4.2.0-30.36 [829 kB]
Get:19 http://us.archive.ubuntu.com/ubuntu/ wily-updates/main libc6-dev amd64 2.21-0ubuntu4.1 [1,958 kB]
Get:20 http://us.archive.ubuntu.com/ubuntu/ wily/main libstdc++-5-dev amd64 5.2.1-22ubuntu2 [1,423 kB]
Get:21 http://us.archive.ubuntu.com/ubuntu/ wily/main g++-5 amd64 5.2.1-22ubuntu2 [15.3 MB]
Get:22 http://us.archive.ubuntu.com/ubuntu/ wily/main g++ amd64 4:5.2.1-3ubuntu1 [1,506 B]
Get:23 http://us.archive.ubuntu.com/ubuntu/ wily/main libblas-common amd64 1.2.20110419-10 [3,058 B]
Get:24 http://us.archive.ubuntu.com/ubuntu/ wily/main libblas3 amd64 1.2.20110419-10 [161 kB]
Get:25 http://us.archive.ubuntu.com/ubuntu/ wily/main libexpat1-dev amd64 2.1.0-7 [115 kB]
Get:26 http://us.archive.ubuntu.com/ubuntu/ wily/main libgfortran3 amd64 5.2.1-22ubuntu2 [258 kB]
Get:27 http://us.archive.ubuntu.com/ubuntu/ wily/main liblapack3 amd64 3.5.0-4 [1,844 kB]
Get:28 http://us.archive.ubuntu.com/ubuntu/ wily/main libpython2.7-dev amd64 2.7.10-4ubuntu1 [27.7 MB]
Get:29 http://us.archive.ubuntu.com/ubuntu/ wily/main libpython-dev amd64 2.7.9-1 [7,836 B]
Get:30 http://us.archive.ubuntu.com/ubuntu/ wily/main make amd64 4.0-8.2 [149 kB]
Get:31 http://us.archive.ubuntu.com/ubuntu/ wily/main manpages-dev all 3.74-1ubuntu1 [1,865 kB]
Get:32 http://us.archive.ubuntu.com/ubuntu/ wily/main python-numpy amd64 1:1.8.2-1ubuntu2 [1,639 kB]
Get:33 http://us.archive.ubuntu.com/ubuntu/ wily/main swig2.0 amd64 2.0.12-1ubuntu1 [875 kB]
Get:34 http://us.archive.ubuntu.com/ubuntu/ wily/main swig amd64 2.0.12-1ubuntu1 [6,320 B]
Fetched 69.9 MB in 1min 24s (823 kB/s)
Extracting templates from packages: 100%
Selecting previously unselected package cmake-data.
(Reading database ... 140037 files and directories currently installed.)
Preparing to unpack .../cmake-data_3.2.2-2ubuntu3_all.deb ...
Unpacking cmake-data (3.2.2-2ubuntu3) ...
Selecting previously unselected package libjsoncpp0v5:amd64.
Preparing to unpack .../libjsoncpp0v5_0.10.5-1_amd64.deb ...
Unpacking libjsoncpp0v5:amd64 (0.10.5-1) ...
Selecting previously unselected package cmake.
Preparing to unpack .../cmake_3.2.2-2ubuntu3_amd64.deb ...
Unpacking cmake (3.2.2-2ubuntu3) ...
Selecting previously unselected package binutils.
Preparing to unpack .../binutils_2.25.1-6ubuntu2_amd64.deb ...
Unpacking binutils (2.25.1-6ubuntu2) ...
Selecting previously unselected package libcc1-0:amd64.
Preparing to unpack .../libcc1-0_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libcc1-0:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libitm1:amd64.
Preparing to unpack .../libitm1_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libitm1:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libatomic1:amd64.
Preparing to unpack .../libatomic1_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libatomic1:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libasan2:amd64.
Preparing to unpack .../libasan2_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libasan2:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package liblsan0:amd64.
Preparing to unpack .../liblsan0_5.2.1-22ubuntu2_amd64.deb ...
Unpacking liblsan0:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libtsan0:amd64.
Preparing to unpack .../libtsan0_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libtsan0:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libubsan0:amd64.
Preparing to unpack .../libubsan0_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libubsan0:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libcilkrts5:amd64.
Preparing to unpack .../libcilkrts5_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libcilkrts5:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libmpx0:amd64.
Preparing to unpack .../libmpx0_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libmpx0:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package libgcc-5-dev:amd64.
Preparing to unpack .../libgcc-5-dev_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libgcc-5-dev:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package gcc-5.
Preparing to unpack .../gcc-5_5.2.1-22ubuntu2_amd64.deb ...
Unpacking gcc-5 (5.2.1-22ubuntu2) ...
Selecting previously unselected package gcc.
Preparing to unpack .../gcc_4%3a5.2.1-3ubuntu1_amd64.deb ...
Unpacking gcc (4:5.2.1-3ubuntu1) ...
Selecting previously unselected package libc-dev-bin.
Preparing to unpack .../libc-dev-bin_2.21-0ubuntu4.1_amd64.deb ...
Unpacking libc-dev-bin (2.21-0ubuntu4.1) ...
Selecting previously unselected package linux-libc-dev:amd64.
Preparing to unpack .../linux-libc-dev_4.2.0-30.36_amd64.deb ...
Unpacking linux-libc-dev:amd64 (4.2.0-30.36) ...
Selecting previously unselected package libc6-dev:amd64.
Preparing to unpack .../libc6-dev_2.21-0ubuntu4.1_amd64.deb ...
Unpacking libc6-dev:amd64 (2.21-0ubuntu4.1) ...
Selecting previously unselected package libstdc++-5-dev:amd64.
Preparing to unpack .../libstdc++-5-dev_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libstdc++-5-dev:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package g++-5.
Preparing to unpack .../g++-5_5.2.1-22ubuntu2_amd64.deb ...
Unpacking g++-5 (5.2.1-22ubuntu2) ...
Selecting previously unselected package g++.
Preparing to unpack .../g++_4%3a5.2.1-3ubuntu1_amd64.deb ...
Unpacking g++ (4:5.2.1-3ubuntu1) ...
Selecting previously unselected package libblas-common.
Preparing to unpack .../libblas-common_1.2.20110419-10_amd64.deb ...
Unpacking libblas-common (1.2.20110419-10) ...
Selecting previously unselected package libblas3.
Preparing to unpack .../libblas3_1.2.20110419-10_amd64.deb ...
Unpacking libblas3 (1.2.20110419-10) ...
Selecting previously unselected package libexpat1-dev:amd64.
Preparing to unpack .../libexpat1-dev_2.1.0-7_amd64.deb ...
Unpacking libexpat1-dev:amd64 (2.1.0-7) ...
Selecting previously unselected package libgfortran3:amd64.
Preparing to unpack .../libgfortran3_5.2.1-22ubuntu2_amd64.deb ...
Unpacking libgfortran3:amd64 (5.2.1-22ubuntu2) ...
Selecting previously unselected package liblapack3.
Preparing to unpack .../liblapack3_3.5.0-4_amd64.deb ...
Unpacking liblapack3 (3.5.0-4) ...
Selecting previously unselected package libpython2.7-dev:amd64.
Preparing to unpack .../libpython2.7-dev_2.7.10-4ubuntu1_amd64.deb ...
Unpacking libpython2.7-dev:amd64 (2.7.10-4ubuntu1) ...
Selecting previously unselected package libpython-dev:amd64.
Preparing to unpack .../libpython-dev_2.7.9-1_amd64.deb ...
Unpacking libpython-dev:amd64 (2.7.9-1) ...
Selecting previously unselected package make.
Preparing to unpack .../make_4.0-8.2_amd64.deb ...
Unpacking make (4.0-8.2) ...
Selecting previously unselected package manpages-dev.
Preparing to unpack .../manpages-dev_3.74-1ubuntu1_all.deb ...
Unpacking manpages-dev (3.74-1ubuntu1) ...
Selecting previously unselected package python-numpy.
Preparing to unpack .../python-numpy_1%3a1.8.2-1ubuntu2_amd64.deb ...
Unpacking python-numpy (1:1.8.2-1ubuntu2) ...
Selecting previously unselected package swig2.0.
Preparing to unpack .../swig2.0_2.0.12-1ubuntu1_amd64.deb ...
Unpacking swig2.0 (2.0.12-1ubuntu1) ...
Selecting previously unselected package swig.
Preparing to unpack .../swig_2.0.12-1ubuntu1_amd64.deb ...
Unpacking swig (2.0.12-1ubuntu1) ...
Processing triggers for man-db (2.7.4-1) ...
Setting up cmake-data (3.2.2-2ubuntu3) ...
Setting up libjsoncpp0v5:amd64 (0.10.5-1) ...
Setting up cmake (3.2.2-2ubuntu3) ...
Setting up binutils (2.25.1-6ubuntu2) ...
Setting up libcc1-0:amd64 (5.2.1-22ubuntu2) ...
Setting up libitm1:amd64 (5.2.1-22ubuntu2) ...
Setting up libatomic1:amd64 (5.2.1-22ubuntu2) ...
Setting up libasan2:amd64 (5.2.1-22ubuntu2) ...
Setting up liblsan0:amd64 (5.2.1-22ubuntu2) ...
Setting up libtsan0:amd64 (5.2.1-22ubuntu2) ...
Setting up libubsan0:amd64 (5.2.1-22ubuntu2) ...
Setting up libcilkrts5:amd64 (5.2.1-22ubuntu2) ...
Setting up libmpx0:amd64 (5.2.1-22ubuntu2) ...
Setting up libgcc-5-dev:amd64 (5.2.1-22ubuntu2) ...
Setting up gcc-5 (5.2.1-22ubuntu2) ...
Setting up gcc (4:5.2.1-3ubuntu1) ...
Setting up libc-dev-bin (2.21-0ubuntu4.1) ...
Setting up linux-libc-dev:amd64 (4.2.0-30.36) ...
Setting up libc6-dev:amd64 (2.21-0ubuntu4.1) ...
Setting up libstdc++-5-dev:amd64 (5.2.1-22ubuntu2) ...
Setting up g++-5 (5.2.1-22ubuntu2) ...
Setting up g++ (4:5.2.1-3ubuntu1) ...
update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode
Setting up libblas-common (1.2.20110419-10) ...
Setting up libblas3 (1.2.20110419-10) ...
update-alternatives: using /usr/lib/libblas/libblas.so.3 to provide /usr/lib/libblas.so.3 (libblas.so.3) in auto mode
Setting up libexpat1-dev:amd64 (2.1.0-7) ...
Setting up libgfortran3:amd64 (5.2.1-22ubuntu2) ...
Setting up liblapack3 (3.5.0-4) ...
update-alternatives: using /usr/lib/lapack/liblapack.so.3 to provide /usr/lib/liblapack.so.3 (liblapack.so.3) in auto mode
Setting up libpython2.7-dev:amd64 (2.7.10-4ubuntu1) ...
Setting up libpython-dev:amd64 (2.7.9-1) ...
Setting up make (4.0-8.2) ...
Setting up manpages-dev (3.74-1ubuntu1) ...
Setting up python-numpy (1:1.8.2-1ubuntu2) ...
Setting up swig2.0 (2.0.12-1ubuntu1) ...
Setting up swig (2.0.12-1ubuntu1) ...
Processing triggers for libc-bin (2.21-0ubuntu4.1) ...
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$ pwd
/home/paul/sdr
paul@sdr:~/sdr$ git clone https://github.com/pothosware/SoapySDR.git
The program 'git' is currently not installed. You can install it by typing:
sudo apt-get install git
paul@sdr:~/sdr$ sudo apt-get install git
git-man liberror-perl
Suggested packages:
git-daemon-run git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitweb git-arch git-cvs git-mediawiki git-svn
git git-man liberror-perl
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 3,759 kB of archives.
After this operation, 24.6 MB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ wily/main liberror-perl all 0.17-1.1 [21.1 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ wily-updates/main git-man all 1:2.5.0-1ubuntu0.1 [728 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ wily-updates/main git amd64 1:2.5.0-1ubuntu0.1 [3,009 kB]
Fetched 3,759 kB in 4s (927 kB/s)
Selecting previously unselected package liberror-perl.
(Reading database ... 147742 files and directories currently installed.)
Preparing to unpack .../liberror-perl_0.17-1.1_all.deb ...
Unpacking liberror-perl (0.17-1.1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../git-man_1%3a2.5.0-1ubuntu0.1_all.deb ...
Unpacking git-man (1:2.5.0-1ubuntu0.1) ...
Selecting previously unselected package git.
Preparing to unpack .../git_1%3a2.5.0-1ubuntu0.1_amd64.deb ...
Unpacking git (1:2.5.0-1ubuntu0.1) ...
Setting up liberror-perl (0.17-1.1) ...
Setting up git-man (1:2.5.0-1ubuntu0.1) ...
Setting up git (1:2.5.0-1ubuntu0.1) ...
paul@sdr:~/sdr$
paul@sdr:~/sdr$
paul@sdr:~/sdr$
Cloning into 'SoapySDR'...
remote: Counting objects: 3973, done.
remote: Total 3973 (delta 0), reused 0 (delta 0), pack-reused 3973
Receiving objects: 100% (3973/3973), 1.91 MiB | 472.00 KiB/s, done.
Resolving deltas: 100% (2985/2985), done.
Checking connectivity... done.
paul@sdr:~/sdr$ ls
SDRplay_RSP_MiricsAPI-1.9.4.run SoapySDR
paul@sdr:~/sdr$ cd SoapySDR
paul@sdr:~/sdr/SoapySDR$ mkdir build
paul@sdr:~/sdr/SoapySDR$ cd build
paul@sdr:~/sdr/SoapySDR/build$ cmake ..
-- The C compiler identification is GNU 5.2.1
-- The CXX compiler identification is GNU 5.2.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Build type not specified: defaulting to release.
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- ## Begin configuration for Python support...
-- Enabling optional Python bindings if possible...
-- Found SWIG: /usr/bin/swig2.0 (found version "2.0.12")
-- SWIG_FOUND: TRUE - 2.0.12
-- Found PythonInterp: /usr/bin/python (found version "2.7.10")
-- PYTHONINTERP_FOUND: TRUE - 2.7.10
-- PYTHON_EXECUTABLE: /usr/bin/python
-- PYTHON_INSTALL_DIR: ${prefix}/lib/python2.7/dist-packages
-- Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython2.7.so (found version "2.7.10")
-- PYTHONLIBS_FOUND: TRUE - 2.7.10
-- PYTHON_INCLUDE_DIRS: /usr/include/python2.7
-- PYTHON_LIBRARIES: /usr/lib/x86_64-linux-gnu/libpython2.7.so
-- ## Begin configuration for Python3 support...
-- Enabling optional Python3 bindings if possible...
-- Found Python3Interp: /usr/bin/python3
-- Could NOT find Python3InterpDbg (missing: PYTHON3_DBG_EXECUTABLE)
-- PYTHON3INTERP_FOUND: TRUE
-- PYTHON3_EXECUTABLE: /usr/bin/python3
-- PYTHON3_INSTALL_DIR: ${prefix}/lib/python3/dist-packages
-- Could NOT find Python3Libs (missing: PYTHON3_LIBRARIES PYTHON3_INCLUDE_DIRS)
-- PYTHON3LIBS_FOUND: FALSE
-- PYTHON3_INCLUDE_DIRS: PYTHON3_INCLUDE_DIR-NOTFOUND
-- PYTHON3_LIBRARIES: PYTHON3_LIBRARY-NOTFOUND
-- ## SoapySDR enabled features
* Library , runtime library v0.4.1-gaee78eb1
* Tests , library unit tests
* Python , python bindings v2.7.10
-- ## SoapySDR disabled features
* Docs , doxygen documentation
* Python3 , python3 bindings
-- SoapySDR version: v0.4.1-gaee78eb1
-- ABI/so version: v0.4-2
-- Install prefix: /usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: /home/paul/sdr/SoapySDR/build
paul@sdr:~/sdr/SoapySDR/build$ make -j4
Scanning dependencies of target SoapySDR
[ 4%] [ 8%] [ 12%] [ 16%] Building CXX object lib/CMakeFiles/SoapySDR.dir/Factory.cpp.o
Building CXX object lib/CMakeFiles/SoapySDR.dir/Device.cpp.o
Building CXX object lib/CMakeFiles/SoapySDR.dir/Registry.cpp.o
Building CXX object lib/CMakeFiles/SoapySDR.dir/Types.cpp.o
[ 20%] Building CXX object lib/CMakeFiles/SoapySDR.dir/NullDevice.cpp.o
[ 24%] Building CXX object lib/CMakeFiles/SoapySDR.dir/Logger.cpp.o
[ 28%] Building CXX object lib/CMakeFiles/SoapySDR.dir/Errors.cpp.o
[ 32%] Building CXX object lib/CMakeFiles/SoapySDR.dir/Formats.cpp.o
[ 36%] Building CXX object lib/CMakeFiles/SoapySDR.dir/Modules.cpp.o
[ 40%] Building CXX object lib/CMakeFiles/SoapySDR.dir/Version.cpp.o
[ 44%] Building CXX object lib/CMakeFiles/SoapySDR.dir/TypesC.cpp.o
[ 48%] Building CXX object lib/CMakeFiles/SoapySDR.dir/ModulesC.cpp.o
[ 52%] Building CXX object lib/CMakeFiles/SoapySDR.dir/VersionC.cpp.o
[ 56%] Building CXX object lib/CMakeFiles/SoapySDR.dir/DeviceC.cpp.o
[ 60%] Building CXX object lib/CMakeFiles/SoapySDR.dir/FactoryC.cpp.o
[ 64%] Building CXX object lib/CMakeFiles/SoapySDR.dir/LoggerC.cpp.o
[ 68%] Building CXX object lib/CMakeFiles/SoapySDR.dir/TimeC.cpp.o
[ 72%] Building CXX object lib/CMakeFiles/SoapySDR.dir/ErrorsC.cpp.o
[ 76%] Building CXX object lib/CMakeFiles/SoapySDR.dir/FormatsC.cpp.o
Linking CXX shared library libSoapySDR.so
[ 76%] Built target SoapySDR
Scanning dependencies of target SoapySDRUtil
[ 80%] Scanning dependencies of target TestTimeConversion
Scanning dependencies of target TestFormatParser
Swig source
[ 84%] Building CXX object apps/CMakeFiles/SoapySDRUtil.dir/SoapySDRUtil.cpp.o
[ 88%] [ 92%] Building CXX object tests/CMakeFiles/TestFormatParser.dir/TestFormatParser.cpp.o
Building CXX object tests/CMakeFiles/TestTimeConversion.dir/TestTimeConversion.cpp.o
Linking CXX executable TestTimeConversion
Linking CXX executable TestFormatParser
[ 92%] Built target TestTimeConversion
[ 96%] Building CXX object apps/CMakeFiles/SoapySDRUtil.dir/SoapySDRProbe.cpp.o
[ 96%] Built target TestFormatParser
Scanning dependencies of target _SoapySDR
[100%] Building CXX object python/CMakeFiles/_SoapySDR.dir/SoapySDRPYTHON_wrap.cxx.o
Linking CXX executable SoapySDRUtil
[100%] Built target SoapySDRUtil
Linking CXX shared module _SoapySDR.so
[100%] Built target _SoapySDR
paul@sdr:~/sdr/SoapySDR/build$ sudo make install
[ 84%] Built target SoapySDRUtil
[ 88%] Built target TestFormatParser
Install the project...
-- Install configuration: "Release"
-- Installing: /usr/local/share/cmake/SoapySDR/SoapySDRConfig.cmake
-- Installing: /usr/local/share/cmake/SoapySDR/SoapySDRUtil.cmake
-- Installing: /usr/local/share/cmake/SoapySDR/SoapySDRConfigVersion.cmake
-- Installing: /usr/local/include/SoapySDR
-- Installing: /usr/local/include/SoapySDR/Types.hpp
-- Installing: /usr/local/include/SoapySDR/Errors.hpp
-- Installing: /usr/local/include/SoapySDR/Time.h
-- Installing: /usr/local/include/SoapySDR/Version.h
-- Installing: /usr/local/include/SoapySDR/Registry.hpp
-- Installing: /usr/local/include/SoapySDR/Logger.h
-- Installing: /usr/local/include/SoapySDR/Formats.h
-- Installing: /usr/local/include/SoapySDR/Version.hpp
-- Installing: /usr/local/include/SoapySDR/Modules.h
-- Installing: /usr/local/include/SoapySDR/Time.hpp
-- Installing: /usr/local/include/SoapySDR/Constants.h
-- Installing: /usr/local/include/SoapySDR/Modules.hpp
-- Installing: /usr/local/include/SoapySDR/Logger.hpp
-- Installing: /usr/local/include/SoapySDR/Formats.hpp
-- Installing: /usr/local/include/SoapySDR/Config.h
-- Installing: /usr/local/include/SoapySDR/Device.hpp
-- Installing: /usr/local/include/SoapySDR/Config.hpp
-- Installing: /usr/local/lib/libSoapySDR.so.0.4.1
-- Installing: /usr/local/lib/libSoapySDR.so.0.4-2
-- Installing: /usr/local/lib/pkgconfig/SoapySDR.pc
-- Installing: /usr/local/bin/SoapySDRUtil
-- Removed runtime path from "/usr/local/bin/SoapySDRUtil"
-- Installing: /usr/local/lib/python2.7/dist-packages/_SoapySDR.so
-- Removed runtime path from "/usr/local/lib/python2.7/dist-packages/_SoapySDR.so"
-- Installing: /usr/local/lib/python2.7/dist-packages/SoapySDR.py
paul@sdr:~/sdr/SoapySDR/build$ sudo ldconfig
paul@sdr:~/sdr/SoapySDR/build$ SoapySDRUtil --info
API Version: v0.4.1-gaee78eb1
ABI Version: v0.4-2
Install root: /usr/local
Module found: /usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so
Loading modules... [ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so)
dlopen() failed: /usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so: undefined symbol: _ZN8SoapySDR6Device18setFrontendMappingEiRKSs
done
Available factories...null,
paul@sdr:~/sdr/SoapySDR/build$ ls /usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so
I was intending to build sdrsoapyplay, just as soon as I got done with sdrsoapy first. There seems no point in going on until I deal with these errors.
Hope that makes sense.
SDRplay.
I built SoapySDRPlay. It generated several warnings about uninitialized or unused variables. But anyway when done SoapySDRUtil then worked as predicted.
Then I tried your recipe to generate CubicSDR. That first "make" should be "cmake" by the way... Then when I fixed that it got an error about OpenGL missing. So I went to that other recipe here:
https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux
I got the base dependencies and the freeglut things (a LOT of stuff). Then I tried the Cubic cmake again and got a complaint about liquid libraries. So I went to their recipe for that farther down the page, and did the git and bootstrap.sh. The latter failed as aclocal, autoconf and autoheader was not there. So now I'm stuck at that point.
The first error about opengl:
CMake Error at /usr/share/cmake-3.2/Modules/FindPackageHandleStandardArgs.cmake:138 (message):
Could NOT find OpenGL (missing: OPENGL_gl_LIBRARY OPENGL_INCLUDE_DIR)
Call Stack (most recent call first):
/usr/share/cmake-3.2/Modules/FindPackageHandleStandardArgs.cmake:374 (_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake-3.2/Modules/FindOpenGL.cmake:168 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
CMakeLists.txt:128 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/paul/sdr/CubicSDR/build/CMakeFiles/CMakeOutput.log".
paul@sdr:~/sdr/CubicSDR/build$ cmake ../ -DCMAKE_BUILD_TYPE=Release
64 bit compiler detected
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libGL.so
-- Found FFTW: /usr/lib/x86_64-linux-gnu/libfftw3.so
-- Could NOT find LIQUID (missing: LIQUID_LIBRARIES LIQUID_INCLUDES)
-- Found wxWidgets: TRUE
-- Copying /home/paul/sdr/CubicSDR/font/*.fnt to directory /home/paul/sdr/CubicSDR/build/x64
-- Configuring file vera_sans_mono48.fnt
-- Configuring file vera_sans_mono24.fnt
-- Configuring file vera_sans_mono12.fnt
-- Configuring file vera_sans_mono18.fnt
-- Configuring file vera_sans_mono32.fnt
-- Configuring file vera_sans_mono16.fnt
-- Copying /home/paul/sdr/CubicSDR/font/*.png to directory /home/paul/sdr/CubicSDR/build/x64
-- Copying /home/paul/sdr/CubicSDR/icon/CubicSDR.ico to directory /home/paul/sdr/CubicSDR/build/x64
-- Configuring file CubicSDR.ico
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
LIQUID_INCLUDES
used as include directory in directory /home/paul/sdr/CubicSDR
LIQUID_LIBRARIES
linked by target "CubicSDR" in directory /home/paul/sdr/CubicSDR
paul@sdr:~/sdr/liquid-dsp$ ls
autotest bench bootstrap.sh configure.ac examples HISTORY include LICENSE makefile.in README.md sandbox scripts src TROUBLESHOOTING
paul@sdr:~/sdr/liquid-dsp$ sudo ./bootstrap.sh
./bootstrap.sh: 30: ./bootstrap.sh: aclocal: not found
./bootstrap.sh: 31: ./bootstrap.sh: autoconf: not found
./bootstrap.sh: 32: ./bootstrap.sh: autoheader: not found
aclocal, autoconf and autoheader are part of automake. To get automake...
sudo apt-get install automake
I plugged in sdrplay and ran the probe:
paul@sdr:~/sdr/CubicSDR/build$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
mir_sdr_Init: gR=40dB fs=2.048MHz rf=222.064MHz bw=1.536MHz if=0.000MHz
mir_sdr_2500_Init: fnaddr = 2 detected, trying to change...
mir_sdr_2500_Init: fnaddr = 6
initHw: Register7 = 0x000005
initHw: Tuner Register0 = 0x04f440
mir_sdr_SetFs: Sample Freq requested 2047999.978065
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=2048000.0+0.0Hz=2048000.0Hz FsToggle->1
mir_sdr_SetRf: f->222064000.000Hz (int=25 frac=20 afc=0) fSynth:3553024000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=222064000.0+0.0+0.0Hz+0.0Hz=222064000.0Hz RfToggle->1
mir_sdr_SetGr: GR->40[16,24,0,0] gRset->0x210 DCCALmode=4 DCCALspd=1 GrToggle->1
mir_sdr_usb_StreamRead: Read failed to read sufficient data: requested 393216 read 0
mir_sdr_2500_StreamRead: Read failed
mir_sdr_2500_StreamRead: Read failed again
setToggleStates: failed mir_sdr_2500_StreamRead err=1
initHw: setToggleStates() Error 1
mir_sdr_Init: initState returns error 7
mir_sdr_2500_Readback001Trim: readback = 0xe30180f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x6c018e
-- Device identification
driver=null
hardware=null
-- Peripheral summary
Channels: 0 Rx, 0 Tx
Timestamps: NO
I ran CubicSDR and it seem to be close. I got the waterfall once but no sound, I guess I need to figure out how to pipe it somewhere. Anyway I need to figure out how it is supposed to be run. It's quite different from gqrx.
