How to Get SDRPlay working with Raspberry Pi
I'm having a bit of trouble getting the SDRplay working with a raspberry Pi 3.
I've downloaded the SDRplay_RSP_MiricsAPI-1.9.2.RPi.run and also the SDRplay_ADS-B_RPi_0.1.run
After they have both run, I still can't get anything to work.
I'm getting the following Error.
Wed May 11 19:16:48 2016 BST dump1090-mutability dump1090_mutability_sdrplay starting up.
Using sample converter: UC8, integer/table path
No supported RTLSDR devices found.
I'm guessing I've missed a Step somewhere, but I can't see to find what.
If i do a lsusb.
Bus 001 Device 032: ID 1df7:2500
So I'm guessing I'm seeing the device
Also a dmesg
usb 1-1.5.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Any idea what I've done wrong?
Thanks for the pointers.
Steve
If i do a lsusb.
Also a dmesg
Steve
Re: How to Get SDRPlay working with Raspberry Pi
When running our modified version of dump1090 you will need the --dev-sdrplay option otherwise it will look for a RTL device.
WOW.
Thanks so Much.
So simple when you know how.
All works great now.
Thanks so Much.
