Remove Center Spike/Spur on display. help
I have a constant spike or spur on the display its on SDRuno and SDRConsole. I understand it maybe a DC Offset or Correction IQ setting but I dont see it anywhere to adjust it. Do others have this? Help to get it removed appreciated.
Re: Remove Center Spike/Spur on display. help
I have the same problem with HDSDR too. Tall narrow center spike sounds like an unmodulated carrier (birdy) as well. There is also some persistant noise spurs on the edges of the "receive hump" I occasionally see as well.
If running in Uno check the ADV panel and check that the DC is checked... Same I'm HDSDR turn on auto dc correcttion and it should remove it
