Using RSP1 in gnuradio with osmocom source block
vincent2718
Post by vincent2718 » Fri Jan 12, 2018 12:06 am
I have RSP1 and use it to listen FM radios with CubicSDR on a machine with Ubuntu 14.04. I installed the special API and blacklisted modules as indicated to me by SDRPlay support team
blacklist sdr_msi3101
blacklist msi2500
blacklist msi001
in the blacklist.conf file.
And it works fine. I can effectively use CubicSDR to listen radios. :D For instance, at the request
SoapySDRUtil --probe="sdrplay" I get the reply
I obtained
Probe device sdrplay
-- Device identification
driver=SDRplay
hardware=1 B0003P0007
mir_sdr_api_version=2.100000
mir_sdr_hw_version=1
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Antennas: RX
Corrections: DC removal
Full gain range: [0, 42] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 3] dB
CORR freq range: MHz
Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
Then I tried to work under gnuradio with a very basic grc schema
I couldn't execute the schema for sometime and obtained the bug 528 message until I understood I should uninstall the gr-osmodr and reinstall it with the instruction
cmake ../ -DENABLE_NONFREE=TRUE
and now gnuradio finds the RSP1 but I have the following message in grc:
Generating: "/home/vincent/Documents/GNURadio/essai_SDRRTL_hardware.py"
Executing: "/home/vincent/Documents/GNURadio/essai_SDRRTL_hardware.py"
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-29-gbc80e972
gr-osmosdr v0.1.4-48-g86ad5842 (0.1.5git) gnuradio 3.7.8
built-in source types: file fcd rtl rtl_tcp uhd sdrplay hackrf bladerf rfspace airspy soapy
get_num_channels: 1
get_num_channels: 1
set_sample_rate start
rate = 1.2e+06
diff = -848000
set_sample_rate end
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
set_center_freq start
freq = 1.011e+08
diff = -9.89e+07
set_center_freq end
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
set_gain started
gain = 50
set_gain end
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
get_num_channels: 1
Using Volk machine: avx2_64_mmx_orc
reinit_device started
after mutex.lock
mir_sdr_Init started
reinit_device end
and the device displays no signal at all.
What should I try now? I am lost :oops: and found no clue as to what I could do on the forum.
Thanking you in advance
Vincent
eagle4321
Re: Using RSP1 in gnuradio with osmocom source block
Post by eagle4321 » Tue Feb 26, 2019 9:20 pm
Did you ever find a solution to this issue? Experiencing the same issue. Tried with a HackRF and it works fine. Seems to be SDRPlay specific.
Post by sdrplay » Mon Mar 18, 2019 7:09 am
The best and easiest way to get up and running with RSPs in Gnu Radio is here:
https://www.sdrplay.com/community/viewt ... f=6&t=3770
Bespoke source blocks for each RSP so that you can control all aspects of the RSP directly.
