However I would like to run WSJT-x on the RP3 and have it use the SDRP as the receiver, but WSJT-x can't find the audio port when I start it. Beyond that, WSJT-x will want to control the rx frequency, which will require additional SDRP driver support.
Can anyone help? Thanks!
pi@SDRPlay:~ $ wsjtx
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pcm.c
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Expression 'parameters->channelCount <= maxChans' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1514
Expression 'ValidateParameters( inputParameters, hostApi, StreamDirection_In )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1838
