I was playing around with SDRPlay today and noticed something that wanted to share with you.
1- It seems there is an internal noise/signal at around 2.48MHZ and all its harmonics (4.96MHZ, 7.5 MHZ, 9.97MHZ, etc). These frequencies may drift over time. This is observed on both RSP1A and RSP2. Changing from Zero-IF to other IF modes changes this frequency. It should not be related to the internal 24MHZ clock I guess.
The noise:
2- RSP2 seems to have much more noise (even when not connected to an external antenna). RSP1A has much cleaner spectrum in comparison.
RSP1A without external antenna:
RSP2 without external antenna:
Does anyone have similar issues?
These tests are done in similar conditions (same OS, software, cable and antenna + automatic gain)
