Skimmer Server support for SDRPlay RSP's
Posted: Fri Apr 27, 2018 2:44 pm
by n2ic
VE3NEA's Skimmer Server (http://www.dxatlas.com/skimserver/) now supports the RSP1, RSP1A and RSP2 using the driver at http://www.kkn.net/~n2ic/SDRPlayIntf.zip . This provides an easy way to get local CW or RTTY spots using your SDRPlay device, and send the spots to the Reverse Beacon Network (www.reversebeacon.net).
Note that Skimmer Server is supported, but CW Skimmer is not supported.
Steve
Re: Skimmer Server support for SDRPlay RSP's
Posted: Mon Aug 20, 2018 12:53 pm
by DD0VS
Hello Steve, all,
i like to make use of the SDRPlayIntf for CW SkimmerSrv but it is not working.
The logfile says:
2018-08-19 22:06:04.884: iled to locate API registry entry error =
2018-08-19 22:06:04.884: myRSP.LoadApi failed
Helps needed!
vy73
Harald
DD0VS
Posted: Fri Sep 28, 2018 6:34 am
by DD0VS
Hello Readers,
meanwhile i updated to the latest SDRplay - API (End of August 18) and to latest SDRPlayIntf (Sept 18).
I got it running with SkimmerServer for CW and RTTY under the following circumstances:
- 192kHz bandwith only
- maximimum of two different bands.
With 3 Bands i got it not running, with less bandwith i got incorrect spots (wrong frequency).
Using 192kHz and 2 Bands everythings is fine and it works for me.
Many Thanks!
vy73
Harald
DD0BS
Posted: Thu Feb 21, 2019 9:03 am
by pa8mm
Hello Steve and all,
Is there any plans for adding support for RSPDuo?
Cheers,
Victor, PA8MM
