Only disturbing signal with SDRPLAY 1
Posted: Sat Jul 28, 2018 10:30 am
by Andre-nl
hi all,
when i startup my application i only have e desturbing signal with mijn SDRPLAY1 (see printscreen please)
this is with a Wellbrook antenne but also without any antenna. does anyone know what it can be ?
Re: Only disturbing signal with SDRPLAY 1
Posted: Sat Jul 28, 2018 6:10 pm
by Paul
could it be computer/computer charger (if laptop) generated?
if laptop, try on battery alone.
Posted: Sun Jul 29, 2018 1:34 pm
by Andre-nl
Paul wrote:could it be computer/computer charger (if laptop) generated?
Hello Paul, i just try it on my laptop with only the Accu and its the same ... the meter is +30 +32dB.
som extra info the SDRPLAY1 sits in an aluminum housing . the signals are the same woth or without antenna.
Posted: Sun Jul 29, 2018 3:26 pm
by Paul
Sorry that it wasn't that simple Andre
My knowledge and experience is very limited, but it might be worth considering LED lights and televisions - my knowledge is now exhausted.
Best of luck,,,
Posted: Mon Jul 30, 2018 4:09 pm
by Andre-nl
Paul wrote:Sorry that it wasn't that simple Andre
Best of luck,,,
no problem Paul, tnx for you support so far. i also send a e-mail to the dealer in Holland i hope maybe he can tel me more ?.
because i dont know if the sdrplay is broken. of something else is the mater ??.
Kind regards
Andre
PS if you (how read this. can help me ?. if so i like to here it)
Posted: Sat Aug 04, 2018 4:19 am
by NoelC
Have you tried a different USB cable?
-Noel
Posted: Thu Aug 09, 2018 11:06 am
by Andre-nl
NoelC wrote:Have you tried a different USB cable?
-Noel
Hello Noel,
i got a new USB cable and i'am sorry to say stil the same problem
Posted: Thu Aug 09, 2018 11:53 am
by Paul
Have you tried another programme?
It might be worth trying SDRuno, just to exclude the possibility of corruption occuring within your version of HSDR, although it does seem unlikely.
You could try removing the antenna to see what effect it has.
Also, another thought, as you are using a laptop, why not take your equipment outside your dwelling (to an electrically quiet location) and try it with a simple antenna to see whether the interference persists or disappears.
Good luck.
Posted: Thu Aug 09, 2018 12:23 pm
by Andre-nl
Paul wrote:Have you tried another programme?
Good luck.
Hi Paul id already test with SDRuno and that gives the same issue. the printscreen you see is without antenne (with is the same).
i wil test it this week outside with my laptop. but other devices here (AOR DV1) etc dont have issues with this.
Posted: Thu Aug 09, 2018 1:53 pm
by Tech_Support
Hello Andre,
I understand that you have a new USB cable, but unless the cable is well shielded, it will act and an antenna and couple external electrical noise into your unit. Good quality ferrites help considerably with this. Regarding readings on your S-meter, only SDRuno has a calibrated S-meter, so values taken from any other programme will be meaningless.
To eliminate external sources of interference, try plugging your device into a laptop that is running on batteries (if you have a laptop that is) and move a an electrically quiet place, well away from network switches, powerline modems, LED lights, plasma TVs etc. With no antenna connected, If the interference goes away then the problem will be coupling via the USB cable.
If it might help, please post screen shots of what you see with SDRuno, so people can see your settings and the level of interference that is accurately measured.
