rtl_airband: SoapySDR lib crash or loop with USBDEVFS_DISCARDURB
drop.drop
Postby drop.drop » Wed Mar 13, 2019 2:48 pm
I found that with latest (13.03.2019) SoapySDR library + SoapySDRPlay library,
the hardware RSP1 freeze.
The following is output of strace. Is possible that the RSP1 is confused my some commands
and stop communicating on USB interface?
Note that after Raspberry reboot RSP1 is found again.
[pid 962] ioctl(10, USBDEVFS_DISCARDURB, 0x3e375f0) = -1 EINVAL (Invalid argument)
[pid 962] ioctl(10, USBDEVFS_DISCARDURB, 0x3e375c4) = -1 EINVAL (Invalid argument)
[pid 962] ioctl(10, USBDEVFS_DISCARDURB, 0x3e37598) = -1 EINVAL (Invalid argument)
[pid 962] ioctl(10, USBDEVFS_DISCARDURB, 0x3e3756c) = -1 EINVAL (Invalid argument)
root@xxxxx:~ # /usr/local/bin/SoapySDRUtil --info
## Soapy SDR -- the SDR abstraction library ##
Lib Version: v0.8.0-g4bfcbc74
API Version: v0.8.0
ABI Version: v0.8
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.8
Module found: /usr/local/lib/SoapySDR/modules0.8/libremoteSupport.so (0.5.2-a6fbf2d)
Module found: /usr/local/lib/SoapySDR/modules0.8/librtlsdrSupport.so (0.3.1-c8c5b92)
Module found: /usr/local/lib/SoapySDR/modules0.8/libsdrPlaySupport.so (0.3.0-31a3a36)
Available factories... remote, rtlsdr, sdrplay
Available converters...
- CF32 -> [CF32, CS16, CS8, CU16, CU8]
- CS16 -> [CF32, CS16, CS8, CU16, CU8]
- CS32 -> [CS32]
- CS8 -> [CF32, CS16, CS8, CU16, CU8]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- F32 -> [F32, S16, S8, U16, U8]
- S16 -> [F32, S16, S8, U16, U8]
- S32 -> [S32]
- S8 -> [F32, S16, S8, U16, U8]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
root@xxxxxx:~ # /usr/local/bin/SoapySDRUtil --find
Found device 0
driver = sdrplay
label = SDRplay Dev0 RSP1A 1XXXXXX96
serial = 1XXXXXX96
Same freeze for /usr/local/bin/SoapySDRUtil --probe
root@xxxxx:~ # /usr/local/bin/SoapySDRUtil --probe
Probe device
strace -fp <pid>
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63310) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac632e4) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac632b8) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac6328c) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63260) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63234) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63208) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac631dc) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac631b0) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63184) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63158) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac6312c) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac63100) = -1 EINVAL (Invalid argument)
[pid 1261] ioctl(15, USBDEVFS_DISCARDURB, 0x9ac630d4) = -1 EINVAL (Invalid argument)
