Dump 1090 issues
Dump 1090 issues
I have read the instructions and downloaded both the dump 1090 software and appropriate api_service as described in the instructions.
My issue is that 1090 works fine by itself in displaying aircraft at my location and I have verified by looing them up in flightaware but i cannot run dump 1090 when SDRUno is running (see attachment ) not sure when else to go to find answers.
Windows 10 64bit
SDRUno v 1.3
8 GB ram
Windows 10 64bit
SDRUno v 1.3
8 GB ram
Re: Dump 1090 issues
Close SDRUno then try dump 1090. Only one application at a time can access an SDRPlay.
Thanks for your suggestion. Dump1090 will work as a standalone but only for 5 minutes. With SDRUno stopped (shutdown) and I start dump1090 here is the message I receive when starting up SDRUno again. when I shut down dump1090 I can again use SDRUno.
It was my understanding that SDRUno and dump1090 would work together as SDRUno is supplying the signals for dump 1090.
- No available rsp.jpg (31.19 KiB) Viewed 19737 times
Perhaps the program operates differently now. When I last used Dump1090 (over a year ago), it ran in conjunction with virtual radar server.
Dump1090 is a standalone program and does not use SDRuno. Ay attempts to run both programs at the same time will not work unless you are using a RSPduo.
Thank you very much Tech Support. I was not aware that dump1090 would only work with RSPduo.
Again Thank you for the clarification.
I think you slightly misunderstand me. What I was saying is that if you want to use dump1090 AND SDRuno at the same time, you will need either two RSPs or a RSPduo as each software package requires a single tuner.
You can use dump1090 on its own with ANY RSP.
