ANT A / ANT B : not working anymore
HI !
I have a problem.
I have an RSP2 receiver from a while.
Today I discovered that switching form ANT-A to ANT-B doesn't work anymore (it was working in the past, i had 2 antennas connected).
Now, with just one antenna connected to ANT-A input, the signal remain exactly the same when I switch from ANT-A to ANT-B.
To further investigate the issue, I've try to connect the antenna to the input ANT-B.
Nothing change. Switching from ANT-A to ANT-B doesn't change anything.
I always see the same signals if the antenna is connected to ANT-A or ANT- regardless of ANT-A / ANT-B software selection.
Seems that for some reason, Antenna input A or Antenna input B are feeding the same frontend, let me say … "a sort of antenna parallel input…"
However, signals are still goods (mean : I'm able to receive weak signals on HF and receive VHF stations).
The only difference I see is when from SdrUno I change to ANT-A or ANT-B to HI-Z : in that case the signal went away (I have no antenna connected tio high impedence antenna connector).
What could be happened ?
Many thanks for any possible comment.
Kind regards
Rick.
I have a problem.
Kind regards
Rick.
Re: ANT A / ANT B : not working anymore
There is a known bug in SDRuno relating to input switching. Try de-installing SDRuno completely, then reboot the PC and then re-install. The problem will probably go away.
