rsp_tcp Gain for sdr consol
Hi friends i am using my new RspDuo with the rsp_tcp server on my and trying to configure the rfgain for Sdr-Console v3.0.11
I am using rtl_tcp compatible mode and is stable but my gains are all messed up anyone got any gain settings for me to try..
I have tried using the SDRServerManager sdr consoles own server but the gain is also bad with mutch lower sigs than before even my rt-sdr v3 has a better gain.
Re: rsp_tcp Gain for sdr consol
I just asked Simon Brown and RSP_TCP is not suported in SDRconsole. I use it and it does not listen to the Gain control but the SNR seems ok. Be aware that the auto gain is not working good and shows to much signal. The manual gain settings are a bit on the low side but this affects only the FFT and the waterfall (visual gain) but the signal quality is not compromised in my setup.
Thanks For Reply Got it got it working using SDR SERVER MANAGER works perfectly all gains available.
