Static from Antenna
illllm
Static from Antenna
Post by illllm » Thu Jan 24, 2019 11:46 pm
Hi All,
I have a loop antenna mounted outside. Its been very cold and dry these days. Today morning, and multiple times after, i received a static shock when i touched the coax to connect it to the RSP2. Should i be concerned ? Do i have to add some protection from antenna to receiver?
thanks much!
Fractal1
Re: Static from Antenna
Post by Fractal1 » Fri Jan 25, 2019 5:24 am
It is unusual to be getting static build up to that degree on a loop, generally random/long wire antennas can generate quite a bit which is always discharged to earth before it gets to the reciever. How is your set up earthed?
illllm
Post by illllm » Fri Jan 25, 2019 1:46 pm
The loop sits on my balcony. Its earthed to the shield only when its connected ( or when i touch it :o :oops: )
Post by Mike2459 » Sat Jan 26, 2019 1:28 am
Illllm:
You were likely the source of the static charge!! Unless you wear a pacemaker I wouldn't be too concerned. Unless you are doing work on a circuit, the electronics should be OK too, not a lot of energy stored in these sorts of discharges.
illllm
Post by illllm » Sat Jan 26, 2019 1:41 am
i think you might be correct. I zap everything i touch in winter.
That being said, do i need to protect the front end from overload/overvoltage ? Would it be okay to use an LNA ?
Post by Paul » Sat Jan 26, 2019 6:52 am
Just a thought...
Do you have any nylon in your floor-covering?
illllm
Post by illllm » Sat Jan 26, 2019 6:52 pm
The floor is carpet, which is nylon i guess.
Post by Paul » Sat Jan 26, 2019 8:44 pm
Perhaps the cause or crontributor to your static problem (particularly in cold weather Ibieve) - Just walking on the carpet would be sufficient i think.
arcosine
Post by arcosine » Sat Jan 26, 2019 10:39 pm
Put a resistor to ground, something like 100k ohm . It will bleed the static without affecting the signal. The spark could destroy your sdr.
Tony
AA9CC
ON5HB
Post by ON5HB » Sun Jan 27, 2019 9:54 pm
Make sure you have the system grounded, even electrical ground is good.
Also, outside at the loop antenna, put a 100 KOhm to 1 MOhm resistor over the 2 poles of the antenna, it will discharge the static to ground....the electrical ground.
I assume you use coax.
If you don't use coax, then take both lines, connect 1 MOhm to them and connect them to grounding, that will remove the static.
Use real resistors and not the modern type ones. You need to old fashion types.
