New user here
Post your feedback here
illllm
Re: New user here
Post by illllm » Fri Jan 25, 2019 1:48 pm
have not used FB for 7 years now - only because I know what goes on behind the scenes ;)
I will poke around some more. Its been working okay since yesterday. I will upload a screenshot of the crash when it happens next.
illllm
Re: New user here
Post by illllm » Fri Jan 25, 2019 3:20 pm
crashed twice today. Screenshot attached.
RSP Error2.JPG (305.12 KiB) Viewed 2820 times
RSP Error.JPG (316.81 KiB) Viewed 2820 times
Re: New user here
Post by g1hbe » Fri Jan 25, 2019 4:09 pm
I think that says RSP error (tune). I've never seen that at all! I'd go to Support and raise a query.
illllm
Re: New user here
Post by illllm » Sat Jan 26, 2019 1:43 am
Support replied. The crash is because Hi-Z is only up to 30mhz. Problem solved.
Re: New user here
Post by Mike2459 » Sat Jan 26, 2019 2:33 am
My RSP2 autoswitches to the A port if I tune the Hi-Z port above 30 MHz. IT DOES NOT GENERATE AN ERROR MSG.
Re: New user here
Post by g1hbe » Sat Jan 26, 2019 8:24 am
Same here Mike. Older versions of SDRUno used to get in a tizz over antenna switching, but it's been sorted out for quite a while now. Very odd. I know there used to be a problem if you accidentally tuned below 0Hz as well, but that one was weeded out a while back too.
illllm
Re: New user here
Post by illllm » Sat Jan 26, 2019 6:51 pm
My RSP2 and software are about 4 days old....
