ADS-B (dump1090) and RSP Command Line Options
IZ2QDD
Post by IZ2QDD » Mon Jan 28, 2019 4:29 pm
Hello everyone, following the guide I found that I can insert commands. For example, I would like to activate the Bias Tee option. I have read the guide, but it does not explain how to insert the various optional commands.
https://www.sdrplay.com/docs/SDRplay_AD ... _Guide.pdf please see page 13
Martien
Re: ADS-B (dump1090) and RSP Command Line Options
Post by Martien » Fri Apr 05, 2019 6:41 am
I know it's a bit late but I just saw your post because I'm experimenting with a homemade colinear antenna and best settings of dump1090 for my setup.
Did you find out how to do it?
If not I can tell you how.
Martien, PD1G
