RSP-SAS Does not run
zs6jpl
Postby zs6jpl » Mon Dec 24, 2018 3:38 pm
I am running a Windows 10 Pro x64 pc. My RSP-1A is working 100% with the SDRUno software. The SDR API is loaded running etc. Unfortunately my RSP-SAS software from Andrew refuses to even start. I checked to make sure the API is in the X86 folder that is needed for SAS. I tried running as administrator, I even uninstalled the SAS software and tried yet again, no luck.
Any wonderful ideas to try to get RSP-SAS to work?
Johan
SteveAndrew
Re: RSP-SAS Does not run
Postby SteveAndrew » Mon Feb 04, 2019 11:18 pm
zs6jpl wrote:I am running a Windows 10 Pro x64 pc. My RSP-1A is working 100% with the SDRUno software. The SDR API is loaded running etc. Unfortunately my RSP-SAS software from Andrew refuses to even start. I checked to make sure the API is in the X86 folder that is needed for SAS. I tried running as administrator, I even uninstalled the SAS software and tried yet again, no luck.
Hi Johan
I'm so sorry I missed this post. If you are still having a problem getting the analyser to run, this may help.
viewtopic.php?f=12&t=3318&start=190
Let me know if this helps, or if you have already got it working. There will be a new version available around the end of this month (February)
Best regards
Steve
Return to “Spectrum Analysis”
