for the last months i was working with a nooelec r820t2 stick on frequencies greater than 100MHz. i´m receiving and decoding radiosondes between 400-406 MHz, Weather Sats on 137-138 MHz and all kind of stuff on 2m and 70cm.
Antenna is a Diamond X-50N Groundplane mounted on the roof, 12m Coax, Software is the latest SDR-Console.
3 Days ago i received the RSP and tried the same things i did with the r820t2 stick, and now i´m very disappointed.
DC Spike & Image Frequencies
Normally the band between 400-406 MHz is empty with weak signals. After "turning on" the receiver a have a DC spike in the middle, that doesnt vanish. And there are two huge intermodulation products/image frequency signals. this is the picture when i change the 1st LO from auto to 168MHz. as far as i understand, this should be the right LO. when the 1st LO is on "Auto" there are even more image frequency signals.
Receiving Radiosonde
This is the normal picture, when a sonde is in the air. the picture was taken 1.5 hours after the start, therefore the signal was quite weak.
With the RSP, i tried different Gain Reductions to establish a readable signal, but failed
Volmet
On 126.000 MHz the DC Spike distorted the AM-Volmet
So please could you give me some hints, what i should do? The results on 2m and 70cm are not better. From my experience now and the evaluation between the nooelec stick an the RSP i want to send the item back. There´s no apparent improvement in reception, maybe my expectation where to high. But maybe i´m doing something wrong ?
Best, Lentas
