Wideband low noise antenna possibility
g,3vds
Postby g,3vds » Mon Dec 05, 2016 1:46 pm
When the weather gets warmer I'm considering one of these:-
http://www.crosscountrywireless.net/ter ... ted_u.html
It seems to have good possibilities connected to an SDRplay. The 390 Ohm resistor can be a low wattage carbon.
Roy
G3VDS, NE5R
lemmy
Re: Wideband low noise antenna possibility
Postby lemmy » Mon Jan 16, 2017 11:48 am
I also like to give this antenna a try. Already made the balun and have the metal box with the resistor.
I`m looking for the two masts for the construction and the give it a try. :-)
NK7Z
Contact:
Postby NK7Z » Mon Jan 16, 2017 4:30 pm
I use a T2FD antenna, and have some actual results from it you can look at here:
http://nk7z.net/sdr-rfi-survey-p1/
This is a short article on using an SDR as a RFI survey tool. Almost every spectrogram shown was taken using a BWD-90, T2FD. It is wide band, and about 6 db down from a dipole... I love it, and use it all the time for both SDR, and normal Ham use...
Return to “SDR Antennas”
