Metal case?
jherbert
Re: Metal case?
Post by jherbert » Thu Apr 28, 2016 5:19 pm
I used Cramolin EMIlac (EMV-Lack) that comes as an aerosol spray. It contains silver plated copper particles and provides 60 to 65 dB attenuation. Very easy to apply, and the result even looks good. Cost per can is about 20 Euros. One can should be sufficient for 0,8 m2.
SDRplay with Cramolin EMIlac (Small).jpg (67.18 KiB) Viewed 20315 times
Don't know if shielding makes a difference, but it is nice to know it's there, anyway.
zwoerdkop
Re: Metal case?
Post by zwoerdkop » Wed May 18, 2016 3:02 pm
Maybe you can find some inspiration here:
http://airspyvertersdrplay.blogspot.nl
The concept here is that the SDRplay is not a device but just a module. You have to build the device yourself, that is the idea.
9a4db
Re: Metal case?
Post by 9a4db » Tue May 31, 2016 8:23 am
My metal box solution.... no more trouble with RF noise from PC PS.
In working position with FT817, antenna splitter, tuner, 10" PC
DK7OB
Re: Metal case?
Post by DK7OB » Wed Jun 01, 2016 7:04 am
9a4db,
very nice solution! I'm going to try it here.
Wolf, DK7OB
xdtony
Re: Metal case?
Post by xdtony » Fri Oct 07, 2016 4:37 am
Picture below is a metal case available on eBay, it gives you another choice if you don't want to create one by yourself.
