Here's what I've discovered using the oscomcom_fft program. Running this without parameters returns an error:
mir_sdr_Init started
mir_sdr_Init: gR=60dB fs=2.000MHz rf=200.000MHz bw=5.000MHz if=0.000MHz
mir_sdr_Init: Fs=2000000Hz is too low for Lif=0 and Bw=5000000 - minimum required 5000000
reinit_device end
dl@t520 ~]$ osmocom_fft -s 5e6 -f 100e6
linux; GNU C++ version 5.1.0; Boost_105800; UHD_003.008.004-0-unknown
gr-osmosdr v0.1.4-45-g46e95395 (0.1.5git) gnuradio 3.7.7
built-in source types: file fcd rtl rtl_tcp uhd sdrplay hackrf bladerf rfspace airspy
get_devices started
mir_sdr_Init: gR=60dB fs=2.048MHz rf=200.000MHz bw=1.536MHz if=0.000MHz
mir_sdr_2500_Init: fnaddr = 2 detected, trying to change...
mir_sdr_2500_Init: fnaddr = 6
initHw: Register7 = 0x000005
mir_sdr_SetRf: f->200000000.000Hz (int=21 frac=3e8 afc=0) fSynth:3200000000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=200000000.0+0.0+0.0Hz+0.0Hz=200000000.0Hz RfToggle->1
mir_sdr_SetGr: GR->60[36,24,0,0] gRset->0x224 DCCALmode=4 DCCALspd=1 GrToggle->1
setToggleStates: initialising sampNum=0x04f48e34, gainSetting=0x224, FsToggle=1, RfToggle=1, GrToggle=1
setToggleStates: initialising Fs=2047999.978, Rf=200000000.000, Gr=60
mir_sdr_Init: already initialised
Device count: 1
sdrplay=0,label='SDRplay RSP'
get_devices end
get_num_channels: 1
[repeated lines removed]
set_gain started
gain = 47
set_gain end
set_sample_rate start
rate = 5e+06
diff = 2.952e+06
set_sample_rate end
get_num_channels: 1
Using Volk machine: avx_64_mmx_orc
get_num_channels: 1
set_center_freq start
freq = 1e+08
diff = -1e+08
set_center_freq end
reinit_device started
after mutex.lock
mir_sdr_Init: gR=60dB fs=5.000MHz rf=100.000MHz bw=5.000MHz if=0.000MHz
initHw: Register7 = 0x000094
initHw: Tuner Register0 = 0x053420
mir_sdr_SetFs: Sample Freq requested 5000000.000000
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=5000000.0+0.0Hz=5000000.0Hz FsToggle->1
mir_sdr_SetRf: f->100000000.000Hz (int=21 frac=3e8 afc=0) fSynth:3200000000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=100000000.0+0.0+0.0Hz+0.0Hz=100000000.0Hz RfToggle->1
setToggleStates: initialising sampNum=0x00017a02, gainSetting=0x224, FsToggle=1, RfToggle=0, GrToggle=0
setToggleStates: initialising Fs=5000000.000, Rf=100000000.000, Gr=60
reinit_device end
I think the problem is the initialization data being sent to the SDRplay is not correct. I tried using the "-a" command line argument to pass initialization arguments as outlined in the SDRplay API documentation but I'm not seeing any indication they being used (at least so far). There is probably a way to do this -- I just haven't figured it out yet. Any help would be appreciated.
I see that Dimitri Stolnikov doesn't have an SDRplay and so hasn't been able to test and tweak the gr-osmosdr implementation of the API. Anyone interested in joining with me to ship Dimitri an SDRplay to work with? Once we get gr-osmosdr working well with SDRplay, gqrx should work as well!
...Doug AH6DL
