Stuttering - Skipping RSP2/SDRUno
EastPier
Post by EastPier » Mon Dec 26, 2016 10:10 pm
This issue appeared last week and has persisted. I can't figure it out. The only settings I have played around with since I got the RSP2 and SDRUno are the sample rate and the gain - I've reverted to the original setting at this stage.
To counter what I perceived to be processing issue, when running the RSP2, I close down all other programmes and CPU usage is showing 20%, max. The computer is a "Core i5"; when running the RSP2, the laptop is off mains power, WiFi is off - I've done everything I can to minimize external interference. The only thing I haven't done is to reset the thing. I'm not a techy so have limited knowledge. Any suggestions/help would be appreciated.
Adrian
daro-1
Re: Stuttering - Skipping RSP2/SDRUno
Post by daro-1 » Tue Dec 27, 2016 8:48 am
I have found an workaround to that issue from SDRuno ver 1.1x and that is to set the DEC in the main panel from 1 to 2 or higher and it seems to stop Stuttering on my SDRuno ver 1.1x
PG3
Post by PG3 » Tue Dec 27, 2016 10:41 am
Also you might try decreasing the zoom in the SP1 window.
EastPier
Post by EastPier » Tue Dec 27, 2016 1:56 pm
Thanks for responding Guys
daro-1 wrote:I have found an workaround to that issue from SDRuno ver 1.1x and that is to set the DEC in the main panel from 1 to 2 or higher and it seems to stop Stuttering on my SDRuno ver 1.1x
I'll give that a go, thanks.
PG3 wrote:Also you might try decreasing the zoom in the SP1 window.
Thanks, decreasing the zoom definitely works, but its a big compromise on the visual aspect.
I downloaded HDSDR for the RSP2. The issue has not arisen with that software, so far. However, I prefer SDRUno as a package - so I'll continue to tweak things and see how it goes.
Tod Yampel
Post by Tod Yampel » Tue Dec 27, 2016 3:23 pm
I agree with PG3.
Decreasing a bit the zoom range on the SP1 screen really helps.
According to the screen shot your CPU consumption is at 76%.
I am running SDRUno with SP2 on the i3 laptop and the CPU consumption is about 47%.
Good luck.
73 KD2JNF
