Record file size
Record file size
Hi;
I have tried the record feature in SDRUno, and am interested in knowing whether there is a way to reduce the file size.
After about 30 mins of recording baseband, I have a total of about 5Gib in several files (each file is a max of about 2Gib).
Also, is there a way to change the default folder into which the saved .wav files are stored?
Frank - KE2KB
Frank - KE2KB
Re: Record file size
Frank,
If you right click on the recording panel it will let you select the folder it will use to store your recordings. I don't know the answer to your question about file size.
73 Martin - G4ENZ
73 Martin - G4ENZ
Thanks. I should have figured that out. Not really paying attention. Too much going on the radio
