I prefer the RSP2 over the RSP1 for it's better selection of filters, gain, and the ability to select multiple antennas. It's the multi-antenna option that drives my question. I want to use port A on the RSP2 to go inline with the single antenna I/O on my 7300 via a Rx/Tx auto-switch. That'll protect that input. This will give me a sub-receiver and better panadapter than Icom's remote software. Hopefully I can figure out rigcontrol so they follow each other.
I want to use port B for reception primarily on VHF and will likely purchase a discone to mount on the roof. This discone would still be relatively close to the end of an 80m dipole and a segment of my 80m horizontal loop. I would also like to listen to FM broadcast this way on days when I work from home. How do I protect port B if I key up my IC-7300 on HF? Do I have to buy a second Rx/Tx switch that is connected to the IC-7300 via a keying line to ground the input to port B? Is protection on port B even necessary in this configuration?
Thank you for reading my long-winded narrative!
