Occupied Uno
OH2BUA
Occupied Uno
Post by OH2BUA » Fri Oct 06, 2017 2:20 pm
SDRplay does not start at all if some other application has 'reserved' the RSP.
I think it should.
Because, SRDuno is not any good for making recordings.
The other one (HDSDR) is way much better in that.
I like to listen (already made recordings) while I'm also recording. Preferrably, with SDRplay.
Ok, the workaround is to use that other SW also for listening.
73, Jukka
OH2BUA
Re: Occupied Uno
Post by OH2BUA » Fri Oct 06, 2017 2:36 pm
Start by fixing this:
> You must enter at least two poll options.
OH2BUA
Re: Occupied Uno
Post by OH2BUA » Fri Nov 24, 2017 7:35 am
Anything new for this - as SDRuno is recently updated?
My RSP2 is very busy almost all the time, monitoring and recording this and that, automatized, occupied by HDSDR.
Meanwhile, I would like to use SDRuno to listen my I/Q recordings. But, SDRuno refuses to start as there are "Not any RSPs available".
Any trick to overcome this?
73, Jukka
Re: Occupied Uno
Post by Tech_Support » Fri Nov 24, 2017 7:55 am
Hello Jukka,
This has been discussed and it is on the list of things to change in SDRuno. I'm afraid I cannot give you a schedule of when it will be done though. It is not quite as straightforward to implement as it might seem.
OH2BUA
Re: Occupied Uno
Post by OH2BUA » Fri Nov 24, 2017 9:20 am
Oh:-I
But thanks for answering.
I have even thought buying a half-broken RSP (RF-end burned or like), but I don't have plans to visit my remote site in person during the winter months.
Luckily, two HDSDRs can be cheated to run at a same time.
Hey, actually my favorite solution would be: Just launch a serious upscale product, I'd buy it for being the second box - problem gone.
73, Jukka
