Frequency response of Ports A and B below 1.5 MHz?
tracey.gardner
Post by tracey.gardner » Thu Dec 28, 2017 11:12 am
The SDRPlay RSP2 has 3 antenna ports. For 50 ohm, port A and B and also a high-Z port.
Ports A and B are specified for reception of 1.5 MHz - 2 GHZ.
Can anybody please tell me the actual frequency response of Ports A and B below 1.5 MHz?
Many thanks
Tracey G5VU
Last edited by tracey.gardner on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Re: Frequency response of Ports A and B below 1.5 MHz?
Post by g1hbe » Thu Dec 28, 2017 1:54 pm
I'm sure the tech team can answer your question, but I've found that both A & B ports start to lose sensitivity below 1.5 MHz. Port B is the worst as it has the bias-T circuitry to cope with. The Hi-z port works supremely well down to a few KHz but it does not have access to the MW rejector, which is a shame. For listening to the beacon band and VLF time-signals I have to use a homebrew LPF. The RSP2 works very well at LF when treated to a decent LPF (see attached image). The hump around 100 KHz is LORAN.
