Sdrplay rsp1a frequency calibration in uk
Hi all,can anyone help me calibrate my sdrplay in the uk.can I calibrate to the he Russian time signal on 9.996?
Regards, Paul
Regards, Paul
Re: Sdrplay rsp1a frequency calibration in uk
Yes, you can calibrate on the standard 9,996 KHz signal. It gives a tick on every second, two ticks on 30 seconds and silence + 2 ticks on the minute. This time signal is sincronized to the German Mainflingen station at 77.5 KHz: DCF77, which can be used as well.
Also in U.K, in Anthorn, Cumbria, you have the 60 KHz MSF station.
More difficult to get, at least in my location (Northern Italy) are the WWV stations at 5, 10 and 15 MHz.
Cheers,
Cheers,
- Russian 9,996 KHz.jpg (192.35 KiB) Viewed 24348 times
Many thanks for your help.
Regards
Regards
Hi there again,on 9.9960 should that be tuned usb or lsb.
Regards.
Regards.
Dear MrPaul,
You should set the receiver in CW, as shown on the uploaded PC screen.
Cheers,
Cheers,
Hi there,do I calibrate in cw mode?
Regards, Paul
Regards, Paul
Thanks for the help.
Regards
Regards
For auto cal, just follow the procedure as shown in the manual. But remember to do it AWAY from the central spike, and to use a known-accurate, steady cal signal.
