Impact of USB cable shield on noise
Sasan
Post by Sasan » Tue Nov 17, 2015 8:44 am
Hi
Here's the results of a very simple experiment I did:
I chose two USB cables to compare (images are attached)
A 0.5 meter unshielded (blue one)
A 1.5 meter shielded (the other one)
Then I tuned to a local FM station. You can see the effect of shield on the noise. The picture with lots of noise (with RED waterfall) is for the blue cable.
All the parameters in this test were equal and unchanged.
Using with shielded cable
With shielded cable.jpg (120.79 KiB) Viewed 13796 times
Using with the simple (blue) cable
Without shielded cable.jpg (103.94 KiB) Viewed 13796 times
Cables side by side
DF2HF, NM9A, EP2C
Alastair_BKA
Re: Impact of USB cable shield on noise
Post by Alastair_BKA » Tue Nov 17, 2015 8:42 pm
Yes a couple of RF Chokes will do wonders for anything that receive or make noise. Your never going to get rid of EMI or RFI but it helps. I am over the top but if we can find a product that stops noise from your electrical outlets. In our world we are really building a Music Studio. Hardware like Icom R-75 or don't suffer so much but sdr equipment does.
Last edited by Alastair_BKA on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
