need help
wrench87
need help
Post by wrench87 » Fri Dec 04, 2015 6:33 pm
I just received my new sdrplay, I am having a problem installing the extio. I am running windows 7 32 bit operating system
it says the install is complete but when i open hdsdr and click on the extio box it says no hardware specific extio-dll found?
any ideas how I get past this.
dlritter
Re: need help
Post by dlritter » Fri Dec 04, 2015 7:19 pm
If I recall correctly, one must drag-n-drop or otherwise place the extio file into the HDSDR folder..
I would double check to see if there might be more than one target.
SDRPlay's version of the installer makes us go find and point to the target.
enjoy
73
Qosmio
Re: need help
Post by Qosmio » Fri Dec 04, 2015 7:24 pm
It seems that you only installed the hardware drivers and not the extio dll software package.
Cheers
Alastair_BKA
Re: need help
Post by Alastair_BKA » Fri Dec 04, 2015 7:45 pm
So your HDSDR folder should looks something like this
Picture 2015-12-04 14_40_00.png (20.97 KiB) Viewed 23226 times
If you cant see it then do a fresh install or just search your computer for the file
Last edited by Alastair_BKA on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
wrench87
Re: need help
Post by wrench87 » Fri Dec 04, 2015 10:39 pm
When I try to open the hdsdr folder it changes to a csv file?, so something is not right.
I will try to do a fresh install.
