SDRuno automatically resets Zero IF to Low IF on every single band change
Ruben_NB4R
Postby Ruben_NB4R » Thu Mar 28, 2019 3:37 am
When I am in any band and change the setting from Low IF to Zero IF and then change bands again, SDRuno will change the setting back to Low IF. Is there a place, that I'm not seeing, that will make this change automatic? After I noticed this I purposely went into every band. Set it for Zero IF and it's reset to back Low IF upon switching bands. This is with version 1.3 of SDRuno.
Also I'm getting the garbled audio described in other threads on almost every start of SDRuno. I just change the Low IF setting to Zero IF to clear this up.
Thank You
Re: SDRuno automatically resets Zero IF to Low IF on every single band change
Postby Mike2459 » Thu Mar 28, 2019 4:17 am
The only time I have experienced garbled audio is:
1) Using the wrong mode
2) Audio and/or RF Gain too high, there are several places in windows audio where audio levels can be set:
a) at sdruno's volume control
b) at the recording input in the windows sound control panel
c) at the volume mixer
3) switching from LowIF to ZeroIF and not tuning off the center spike, never from ZIF to LIF
4) In stereo wide FM mode 192k bandwidth only, if SDRuno's volume is advanced past midway the audio will be distorted.
5) Excessively high RF input from antenna
Ruben_NB4R
Postby Ruben_NB4R » Fri Mar 29, 2019 3:10 am
Mike, thanks for the list. I can say in this case nothing on the list is causing the problem with garbled audio. My real question is why does SDRuno change the software form Zero IF to Low IF on every single band change?
Postby Mike2459 » Fri Mar 29, 2019 5:20 am
What do you mean by band change? Every time a new frequency is manually entered? Or changing the band presets on the keypad?
I've tried to make this happen (IF mode changing to Z-IF from Lo-IF) and I can't reproduce this issue. I must be misunderstanding something here.
I was finally able to see what you mean. I thought the presets at one time operated in Zero-IF on the preset. Anyway, all I can say is the developers chose to set it up this way. Why? You''ll have to ask them.
Postby Tech_Support » Fri Mar 29, 2019 7:33 am
Low IF is a better option for the band presets for the HF bands and lower as it results in fewer spurious mixing products from the block converter that is used for covering HF. This is explained in the following application note:
https://www.sdrplay.com/docs/SDRplay_Op ... _MW_HF.pdf
Many people mistakenly confuse spurious higher order mixing products with intermodulation. Intermodulation arise from non-linearities, but higher order mixing product do not.
The other advantage of Low IF mode is that it avoids the need to have the LO and VFO separated.
In the next release, we are going to make it easier to toggle between Low IF and Zero IF modes.
Ruben_NB4R
Postby Ruben_NB4R » Fri Mar 29, 2019 6:31 pm
Thank you Mike and Thank you Tech_Support for your responses. I was just curious as to why this was happening. I was about to uninstall SDRuno and do an install of 1.3 to see if tat didn't happen. I'm glad to know that is normal. You guys have done a great job with SDRuno and keep up the good work. have a wonderful weekend.
Regards
Ruben_NB4R
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 4 guests
