Decimation defaults to 1.
pmendes
Postby pmendes » Wed Apr 10, 2019 12:58 am
I for one do not like this new decimation setting scheme. I liked it as in the last revision where it stays at the level you set it. It's really annoying having to reset the decimation when changing the frequency from the memory panel, etc. If there is an option for a persistent decimation level please let me know.
Re: Decimation defaults to 1.
Postby Tech_Support » Wed Apr 10, 2019 6:30 am
Whatever gets changed to fix a problem that some people find really annoying inevitably leaves someone else feeling really annoyed.
We will look at this problem again to see if there is a better way on the next release which will now be 1.4.
Postby Mike2459 » Wed Apr 10, 2019 5:06 pm
Seems like Larry, Moe & Curly have done it again :lol:
MNZCH
Postby MNZCH » Fri Apr 12, 2019 9:36 am
pmendes wrote:I for one do not like this new decimation setting scheme. I liked it as in the last revision where it stays at the level you set it. It's really annoying having to reset the decimation when changing the frequency from the memory panel, etc. If there is an option for a persistent decimation level please let me know.
Agree, when using mem panel and switching between saved frequencies, decimation should not revert back to [1].
sdrom33
Postby sdrom33 » Sat Apr 13, 2019 5:29 am
Also if decimation is too low my audio starts highcupping and if I do not change quickly it crashes. Better let decimation setting alone in next issue.
MNZCH
Postby MNZCH » Tue Jul 09, 2019 9:13 pm
Thank you very much for resolving the decimation reset issue in version 3.12.
