Scan Mem Banks Error
n7esu
Post by n7esu » Fri Apr 19, 2019 11:37 pm
I can scan freq's ok but when I try to scan the memory bank channels I get
Internal error application will terminate
Is not a valid floating point value
Stack trace (null)
qualifiedclassname: system.sysutils.econvert error
What am I doing wrong????
Jim-n7esu
Re: Scan Mem Banks Error
Post by Tech_Support » Sat Apr 20, 2019 5:04 am
Hello Jim,
This almost certainly means that you have a formatting error in your S1b file. If you imported it or modified it in some way, check that you do not have text in your frequency field for any of the entries. The S1b file is a CSV file and there is no text header, so the first line of this file is your first memory entry.
n7esu
Post by n7esu » Sat Apr 20, 2019 12:48 pm
Yes when I opened up the files I did find some errors.
Thank you for your help all is good now.
Also thanks for a great product.
Jim
n7esu
