Noise cancellation with SDRuno V1.32
Post by Tech_Support » Fri Jul 12, 2019 12:48 pm
Here is a great example of how Release 1.32 can be used for local noise cancellation:
https://youtu.be/2ptiTxU2wMU
The user uses a LZ1AQ active loop which is connected to Tuner 1 of RSPduo, and a active whip connected to Tuner 2. The two antennas are placed 5m apart. Note that the Auto mode is NOT designed for noise cancellation. Auto is for MRC diversity only. For noise cancellation, you need to turn auto off and adjust manually as shown in the video.
