Recording 2 I/Q streams
Does anyone know if both the I/Q streams of the RSPduo with SDRuno can be recorded to a internal HD simultanious? A 2 MHz sample rate will be used for both receivers.
I like to make recordings for comparing antennas at night on MW.
An external USB 3.0 drive will also be fine but I guess the ports from the pc will be swamped with to much data.
73' Ron
73' Ron
Re: Recording 2 I/Q streams
No issues on my end doing that but my recordings are going to a 2nd internal HD
Thanks Mike! I also use a second HD for this. I do not like to record I/Q files on a HD with the W10 OS mounted.
I'm using a Intel NUC8i5BEH with a Samsung 970 evo 500 Gb SSD and a WD 2Tb 2.5" HD.
Want to make a Mediumwave I/Q recording with a Beverage with Tuner 1 and an experimental Lira antenna with Tuner 2.
The Lira is still in test and should outperform the Beverage in theory
See ya,
Ron
See ya,
Ron
No problem, My main drive is an SSD. I try to keep anything that writes constant data to it at a minimum if possible.
