After installing the API, use this command to make sure the RSP can be seen by the system and afterwards make sure the RSP is disconnected and reconnected.
sudo service udev restart
Here’s the code you need to build SoapySDR and SoapySDRPlay on Linux/x86…
Note: this code assumes that you have a Dev directory in your home account and will remove any existing SoapySDR and SoapySDRPlay directories you may have within it. If you do not have a Dev directory, create one using mkdir ~/Dev
Build SoapySDR…
cd ~/Dev
sudo rm -rf SoapySDR
git clone https://github.com/pothosware/SoapySDR.git
cd SoapySDR
mkdir build
cd build
cmake ..
make
sudo make install
sudo ldconfig
Build SoapySDRPlay…
cd ~/Dev
sudo rm -rf SoapySDRPlay
git clone https://github.com/pothosware/SoapySDRPlay.git
cd SoapySDRPlay
mkdir build
cd build
cmake ..
sudo make install
sudo ldconfig
To check the SoapySDR installation, type the following into a terminal window:
SoapySDRUtil -info
and also
SoapySDRUtil --probe="driver=sdrplay"
If you have any problems at this point, please raise a ticket here and we will help you further.
Everything is ok – Where next?
CubicSDR – there are prebuilt appImages for Linux/x86 available from the CubicSDR website if you click here
Home Page – go back to our home page by clicking here
