linux mint 18.1 sdrplay, windows xp look
snifferdsx
Postby snifferdsx » Sun May 21, 2017 9:35 am
hi i am nl13833
this is a howto how i have install it on Mint 18.1
CubicSDR
cqelog, fldigi and wjst-x
qsstv
last shot is from my ubuntu 16.04 in apple style
now i tell you how i all heve install on Linux mint 18.1 it works on ubuntu 16.04 too only then you get 2 error in the install script from gnu radio
press
ctrl+alt+T
this open a terminal window
first install linuxmint 18.1 i have use this version https://www.linuxmint.com/edition.php?id=226 if you not know how here are the docs https://www.linuxmint.com/documentation.php
sudo apt update && sudo apt upgrade
sudo locale-gen --purge –no-archive (https://forums.linuxmint.com/viewtopic.php?t=111527)
cd ~/ && mkdir source && cd source
download API/Hardware Driver – version 2.10 http://www.sdrplay.com/downloads/#tab-t ... 0-2-5037-1
chmod +x SDRplay_RSP_API-Linux-2.10.1.run
sudo ./SDRplay_RSP_API-Linux-2.10.1.run
sudo ldconfig
sudo apt install -y git build-essential automake cmake swig
sudo apt install -y libpulse-dev libgtk-3-dev
sudo apt install -y freeglut3 freeglut3-dev
https://github.com/pothosware/SoapySDR/wiki
Build SoapySDR
git clone https://github.com/pothosware/SoapySDR.git
cd SoapySDR
mkdir build && cd build
cmake ../ -DCMAKE_BUILD_TYPE=Release
make -j4 && sudo make install && sudo ldconfig
cd ~/source
https://github.com/pothosware/SoapyRemote/wiki
Build SoapyRemote
git clone https://github.com/pothosware/SoapyRemote.git
cd SoapyRemote
make && sudo make install && sudo ldconfig
cd ~/source
https://github.com/pothosware/SoapyAudio/wiki
Build SoapyAudio
git clone https://github.com/pothosware/SoapyAudio.git
cd  SoapyAudio
make && sudo make install sudo ldconfig
cd ~/source
SoapySDRUtil --info (you get this to see)
Lib Version: v0.6.0-g74f890ce
API Version: v0.6.0
ABI Version: v0.6
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.6
Module found: /usr/local/lib/SoapySDR/modules0.6/libaudioSupport.so
Module found: /usr/local/lib/SoapySDR/modules0.6/libremoteSupport.so
Loading modules... done
Available factories...audio, null, remote,
SoapySDRUtil --probe
Probe device
-- Device identification
driver=Audio
hardware=Audio
device_id=0
origin=https://github.com/pothosware/SoapyAudio
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* Stereo Sample Offset - Offset stereo samples for off-by-one audio inputs.
[key=sample_offset, default=0, type=string, options=(-2, -1, 0, 1, 2)]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS8, CS16, CF32
Native format: CS16 [full-scale=65536]
Stream args:
* Channel Setup - Input channel configuration.
[key=chan, default=mono_l, type=string, options=(mono_l, mono_r, stereo_iq, stereo_qi)]
Antennas: RX
Full gain range: [0, 0] dB
Full freq range: [0, 6000] MHz
RF freq range: [0, 6000] MHz
Sample rates: 0.008, 0.016, 0.02205, 0.032, 0.0441, 0.048, 0.096 MSps
Build and install liquid-dsp
git clone https://github.com/jgaeddert/liquid-dsp
cd liquid-dsp
./bootstrap.sh
CFLAGS="-march=native -O3" ./configure --enable-fftoverride
cd ~/source
Build static wxWidgets
wget https://github.com/wxWidgets/wxWidgets/releases/download/v3.1.0/wxWidgets-3.1.0.tar.bz2
tar -xvjf wxWidgets-3.1.0.tar.bz2
cd wxWidgets-3.1.0/
mkdir -p ~/Develop/wxWidgets-staticlib
./autogen.sh
./configure --with-opengl --disable-shared --enable-monolithic --with-libjpeg --with-libtiff --with-libpng --with-zlib --disable-sdltest --enable-unicode --enable-display --enable-propgrid --disable-webkit --disable-webview --disable-webviewwebkit --prefix=`echo ~/Develop/wxWidgets-staticlib` CXXFLAGS="-std=c++0x"
make -j4 && make install
cd ~/source
[ building and installed to ~/Develop/wxWidgets-staticlib in this example ]
http://www.hamlib.org
Build Hamlibs
sudo apt install texinfo
git clone https://github.com/N0NB/hamlib.git
cd hamlib
./autogen.sh
cd ~/source
or you can install them
sudo apt-get install libhamlib2 libhamlib-utils libhamlib++-dev libhamlib-dev libhamlib-doc python-libhamlib2
Build CubicSD
git clone https://github.com/cjcliffe/CubicSDR.git
cd CubicSDR
cmake ../ -DUSE_HAMLIB=1 -DCMAKE_BUILD_TYPE=Release -DwxWidgets_CONFIG_EXECUTABLE=~/Develop/wxWidgets-staticlib/bin/wx-config
make
cd x64/
./CubicSDR then close it
cd ..
cd ~/source
Build SoapySDRPlay
git clone https://github.com/pothosware/SoapySDRPlay.git
cd SoapySDRPlay
cmake .. -DCMAKE_BUILD_TYPE=Release
cd ~/source
SoapySDRUtil –info
API Version: v0.6.0
ABI Version: v0.6
Module found: /usr/local/lib/SoapySDR/modules0.6/libsdrPlaySupport.so
Available factories...audio, null, remote, sdrplay,
SoapySDRUtil –probe
Probe device
fwDownload: FW image size = 6083
mir_sdr_usb_GetDevices Dev0:vid=1df7 pid=3010 rev=0207 serno=160505Cxxx bus=002 port=001 devAvail=1
driver=Audio
hardware=Audio
device_id=0
Timestamps: NO
Other Settings:
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream args:
Antennas: RX
sudo apt-get install \
    libnuma-dev \
    libpython-dev python-numpy \
    qtbase5-dev libqt5svg5-dev libqt5opengl5-dev libqwt-qt5-dev \
    portaudio19-dev libjack-jackd2-dev \
    graphviz
sudo add-apt-repository -y ppa:pothosware/support
sudo add-apt-repository -y ppa:pothosware/framework
sudo apt-get update
    libpoco-dev \
    libspuce-dev \
    libmuparserx-dev \
    libpothos-serialization-dev
https://github.com/pothosware/pothos/wiki
build pothos
git clone --recursive https://github.com/pothosware/pothos.git
cd pothos
cmake ../ && make -j4 && sudo make install && sudo ldconfig
PothosUtil --self-tests
PothosGui
cd ~/source
sudo apt install python-ply python-yaml python-mako
build GNU Radio this take very long
cd ~/source
mkdir gnuradio
cd gnuradio
wget http://www.sbrac.org/files/build-gnuradio && chmod a+x build-gnuradio && ./build-gnuradio
cd ~/source
answer on all questions Y
Build gr-osmosdr
git clone git://git.osmocom.org/gr-osmosdr
cd gr-osmosdr/
mkdir build && cd build/
cmake ../ -DENABLE_NONFREE=TRUE
cd ~/source
build gr-pothos
https://github.com/pothosware/gr-pothos/wiki
git clone https://github.com/pothosware/gr-pothos.git
cd gr-pothos
#set CMAKE_INSTALL_PREFIX to match the GNU Radio install
cmake ../ -DCMAKE_INSTALL_PREFIX=/usr/local
make -j8 && sudo make install && sudo ldconfig
cd ~/source
this part you need for openwebrx
build csdr
git clone https://github.com/simonyiszk/csdr.git
cd csdr
cd ~/source
build rx_tools
https://github.com/rxseger/rx_tools
git clone https://github.com/rxseger/rx_tools
cd rx_tools
cmake ..
sudo nano /etc/modprobe.d/blacklist-sdrplay.conf
blacklist sdr_msi3101
blacklist msi001
blacklist msi2500
xtrl+x y then enter
SoapySDRUtil --find
mir_sdr_usb_GetDevices Dev0:vid=1df7 pid=3010 rev=0207 serno=160505CXXX bus=002 port=001 devAvail=1
Found device 0
default_input = True
default_output = True
device_id = 0
driver = audio
label = PulseAudio
Found device 1
driver = sdrplay
label = SDRplay Dev0 RSP2 160505CXXX
cd ~/
git clone https://github.com/simonyiszk/openwebrx.git
cd openwebrx
nano config_webrx.py
https://github.com/simonyiszk/openwebrx ... -OpenWebRX
copy the Step #4: Edit OpenWebRX configuration in the config_webrx.py
soapy_device_query="0" change this part to soapy_device_query="driver=sdrplay"
to run
python2 openwebrx.py
is is the first part .. i hope you like it
46flatlander
Re: linux mint 18.1 sdrplay, windows xp look
Postby 46flatlander » Sun May 21, 2017 10:59 pm
Nice job,I started a similar install on 14.04 but ran into the Gnuradio bug! So I changed course and installed
Skywave Linux,had to repair known sound bug (easy) repair ,wasn't happy with Desktop changed same. Very
happy with final product,can now run all my Linux programs and listen to SDRplay at same time.Very pleased
with Cubic SDR program interfaces nicely with Cubic SDR! Hojon Lee
Last edited by 46flatlander on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
snifferdsx
Postby snifferdsx » Mon May 22, 2017 5:53 am
sudo ldconfig
i forgot somthing
it must be
cd ~/Downloads
sudo ldconfig
cd ~/source
snifferdsx
Postby snifferdsx » Wed May 24, 2017 9:38 pm
by Build SoapyAudio
is forgot && in the install line
this moest be
Build Hamlibs
cd hamlib
./autogen.sh
cd ~/source
you nwwd by this part install libtool
sudo apt install libtool
sorry i cant not mod my first post so i do it on this way
snifferdsx
Postby snifferdsx » Fri Jun 02, 2017 9:23 am
cqrlog
sudo add-apt-repository ppa:ok2cqr/ppa;sudo apt update;sudo apt install -y cqrlog xplanet*
homepage https://cqrlog.com
wsjtx
sudo apt install -y pavucontrol
sudo add-apt-repository -y ppa:ki7mt/wsjtx-next
sudo apt update
sudo apt install -y  wsjtx
click left on the bottem then type pulse on the search bar
click then on record then monitor on buld-in audio
if you have not run a programma you will see here nothing
fldigi
sudo add-apt-repository ppa:kamalmostafa/fldigi
sudo apt update
sudo apt install -y fldigi
qsstv
sudo apt install -y g++ libfftw3-dev qt5-default libpulse-dev
sudo apt install -y hamlib-dev libasound-dev libv4l-dev
sudo apt install -y libopenjp2-7 libopenjp2-7-dev
cd ~/source
wget http://users.telenet.be/on4qz/qsstv/downloads/qsstv_9.2.4.tar.gz
tar -xvzf qsstv_9.2.4.tar.gz && cd qsstv_9.2.4
qmake && make
snifferdsx
Postby snifferdsx » Fri Jun 02, 2017 3:01 pm
last part
click with the right mousebutton on the bar below
click on themes
click on "add/remove desktop themes"
click on "Available themes"
click in the search tab xp
select 1 and click on "install or update ..."
click 2x on the theme you want use
the background and the logo in menu must install manual
close the desktop themes window and themes
http://tinyurl.com/yar2wum4
open this link and save the xp logo
turn panel mode edit "on"
click with the right mousebutton on the menu button
click on "configure"
turn on "use a custom icon"
click on the menu logo and select  your saved logo
change by text "menu" to "start"
turn panel mode edit "off"
http://tinyurl.com/yb463bza
open the link
select een desktop and save it to "pictures"
or save it as "set as desktop background"
select "system settings"
click on "Backgrounds"
click op "pictures" and select backround
i hope this is clear enough
snifferdsx
Postby snifferdsx » Wed Jun 07, 2017 5:20 am
hi all
i have make a sdcard image from this all is there some one who have intrest in it it have a other look
this dont works yet the sdrplay wine fake ddl is for a other api and the sit from it have a html error 500
sane problem
