SoapySDRPlay compile error on Unbuntu 14
brucep
Postby brucep » Sat Jun 03, 2017 8:09 am
My last post seemed to go astray ! Apologies if this is the second time you see this.
I have been unable to install Skywave Linux, as the mini PC target I'm using can't install anything Ubuntu 16 due to a video issue.
So I'm been trying the long way to install under Ubuntu 14, following the github guide for CubicSDR linux installation given.
Before that, I was able to successfully install the SDRPlay 2.10 libraries using the .run file.
[NB: wxWidgets 3.1.0 version is not where the guide says anymore, but I was able to get it as a zip file OK].
The problem occurs when I attempt to make SoapySDRPlay:
$ make
Scanning dependencies of target sdrPlaySupport
[ 33%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Registation.cpp.o
[ 66%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Settings.cpp.o
[100%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Streaming.cpp.o
Linking CXX shared module libsdrPlaySupport.so
/usr/local/lib/libmirsdrapi-rsp.so: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
make[2]: *** [libsdrPlaySupport.so] Error 1
make[1]: *** [CMakeFiles/sdrPlaySupport.dir/all] Error 2
make: *** [all] Error 2
I saw elsewhere that SDRPlay say the 2.10 libraries are backwards compatible with 1.97 (which the guide used), so I don't understand why I'd get this error ?
octave9
Re: SoapySDRPlay compile error on Unbuntu 14
Postby octave9 » Sat Jun 03, 2017 11:33 am
I see your original post has appeared. Pretty sure it wasn't there earlier, so a forum glitch I guess.
I'd recommend trying to follow the 'Non-Windows Workflow' pdf at http://www.sdrplay.com/downloads/ but I see there's still a mistake (or two) in it.
Both the cjcliffe guide on the github Wiki and the Workflow guide say the same URL for WxWidgets and it seems to be working today. Maybe try to wget it again in case the contents of the zip you mentioned is causing the problem. I got it with:
wget https://github.com/wxWidgets/wxWidgets/ ... .0.tar.bz2
There's an unfortunate line break in section 6.2 of the Workflow guide which may have caught you out, so use the line above. Similarly; the line which says 'cd wxWidgets=3.1.0' should say 'cd wxWidgets-3.1.0'.
The ./configure line splits when you copy it, so use:
./configure --with-opengl --disable-shared --enable-monolithic --with-libjpeg --with-libtiff --with-libpng --with-zlib --disable-sdltest --enable-unicode --enable-display --enable-propgrid --disable-webkit --disable-webview --disable-webviewwebkit --prefix=`echo ~/Dev/wxWidgets-staticlib` CXXFLAGS="-std=c++0x"
Which you should be able to cut n paste as one very long command line...
Hoping it helps, but ask again if you're still stuck. Seems there are a few users who prefer Linux - even over the quite nice SDRUno...
octave9
Postby octave9 » Sat Jun 03, 2017 11:39 am
Section 6.2 of the workflow doc has been fixed in the version now available. The back-slashes make the command work by 'escaping' the line breaks (I think). 8-)
brucep
Postby brucep » Tue Jun 06, 2017 4:09 am
Thanks for your replies about wxWidgets. I actually got through that bit OK, even if not quite the way described in the guide. I downloaded a zip file to a windows box of v3.1.0 tag, unzipped it there and copied the whole lot to the Ubuntu 14 PC. All configured and compiled OK. CubicSDR actually runs, but there are no devices.
The problem I experienced was with SoapySDRPlay, which I ultimately need to talk to my SDRPlay box ! I might be wrong, but I don't think SoapySDRPlay has any dependency on wxWidgets at all. It seems like the libmirsdrapi-rsp.so I have installed isn't what the rest of Soapy expects to see.
Postby sdrplay » Thu Jun 08, 2017 9:13 pm
That error means you have the wrong API for your system. What is your system (processor type) and what API did you download?
brucep
Postby brucep » Tue Jun 20, 2017 9:07 am
I have an x6_64 target.
I downloaded the .run file and ran it, so I don't know what API type I have downloaded. Is there some sort of auto-detection ? I couldn't see anything obvious in the .run file itself.
If the run file only gets x86 target API, how do I get the x86_64 version from the SDRPlay website ?
Postby sdrplay » Tue Jun 20, 2017 9:41 am
That error means the .so is in the wrong format for your system. What OS and processor are you using?
src1138
Postby src1138 » Thu Jul 27, 2017 1:34 pm
Hi - I am having the same problem.
OS: Ubuntu 16.04 LTS 64-bit
Processor: Intel® Core™ i3-4030U CPU @ 1.90GHz × 4
I kept running into this problem when trying to build SoapySDRPlay on a pre-existing install of Ubuntu 16.04 LTS 64-bit, so I did a clean install and still get an error on make:
-- Build files have been written to: /home/src1138/backup_20170727/Desktop/sdrplay/SoapySDRPlay/build
[ 25%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Registation.cpp.o
[ 50%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Settings.cpp.o
[ 75%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Streaming.cpp.o
[100%] Linking CXX shared module libsdrPlaySupport.so
CMakeFiles/sdrPlaySupport.dir/build.make:148: recipe for target 'libsdrPlaySupport.so' failed
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/sdrPlaySupport.dir/all' failed
Makefile:127: recipe for target 'all' failed
[ 25%] Linking CXX shared module libsdrPlaySupport.so
Any help would be appreciated - I am stuck with an RSP2 I can´t use :(
Postby sdrplay » Thu Jul 27, 2017 2:26 pm
As I asked above, what processor are you running on? The format error means you have the wrong API library for the processor you are using.
Postby sdrplay » Thu Jul 27, 2017 3:04 pm
Sorry, you do mention the processor - can you say what API download you are using?
