make sdruono easier to read
Hi all,
does anyone have any tips/tricks to make sdruno easier to read
thanks Beau
thanks Beau
Re: make sdruono easier to read
You can try lowering your systems display resolution.
I forgot to add the following that SDRuno auto populates its panels based on preset resolutions. This is valid only for an unaltered "default" workspace.
Which is workspace 0
Try the following.
Lower your system resolution
Launch SDRuno
Select an unused Workspace from the MAIN panel. 1-9
You will only see the MAIN panel
Click the MAIN panel SETT. button.
Select the AUTO LAYOUT option
Select DEFAULT
SDRuno will now rebuild the panels based its preset resolution to match your system resolution
(as shown on page 21 of the SDRuno manual)
https://www.sdrplay.com/docs/SDRplay_SD ... Manual.pdf
Hope this makes sense
Try the following.
Launch SDRuno
Select DEFAULT
