Using SDRPlay With HF/VHF/UHF Tranceiver
M6WCL
Post by M6WCL » Wed Jan 04, 2017 4:18 pm
Hi Everyone
I am looking to get a transceiver for amateur / ham radio usage. However most of the radios do not have a RX out port.
I could run an additional wire antenna direct to the SDRPlay but this is unlikely to match my existing antenna's performance and might not be so good as using a separate antenna for VHF. Also it might cause overloading on transmit.
I am interested to know of other people's solutions where they have a similar radio with no RX out and they are utilising the benefits of SDRPlay to show a large part of the spectrum.
Thanks!
lauchlin
Re: Using SDRPlay With HF/VHF/UHF Tranceiver
Post by lauchlin » Thu Jan 05, 2017 2:29 pm
My HF Radio is Ten Tec Orion no receive out and no software command to mute audio ..I us a Switch Box made by Elad to control rf and audio and i use one antenna 80 Meter loop @ 60 ft it has worked well for me last 2 years i use a Elad sdr or Afedri and now messsing with RSP2 ..........
http://ecom.eladit.com/ELAD-ASW-1-SWITC ... -Exchanger
VE7SHM
