RSP2 and API 2.13.1
Rebel
RSP2 and API 2.13.1
Postby Rebel » Thu Jul 19, 2018 11:07 am
after updating to API2.13.1 and pulling SoapySDR and SoapySDRPlay from Git, compile and install it, the RSP2 is not recognized anymore.
Any idea what could be wrong?
SoapySDRUtil --info output shows:
## Soapy SDR -- the SDR abstraction library ##
Lib Version: v0.7.0-gcea2ae17
API Version: v0.7.0
ABI Version: v0.7
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.7
Module found: /usr/local/lib/SoapySDR/modules0.7/libLMS7Support.so (18.04.1-00c66d4)
Module found: /usr/local/lib/SoapySDR/modules0.7/librtlsdrSupport.so (0.2.5-ad3d8e0)
Module found: /usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so (0.1.0-12c3db6)
Available factories... lime, rtlsdr, sdrplay
Available converters...
- CF32 -> [CF32, CS16, CS8, CU16, CU8]
- CS16 -> [CF32, CS16, CS8, CU16, CU8]
- CS32 -> [CS32]
- CS8 -> [CF32, CS16, CS8, CU16, CU8]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- F32 -> [F32, S16, S8, U16, U8]
- S16 -> [F32, S16, S8, U16, U8]
- S32 -> [S32]
- S8 -> [F32, S16, S8, U16, U8]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
Thanks in advance
Fred
Rebel
Re: RSP2 and API 2.13.1
Postby Rebel » Thu Jul 19, 2018 11:56 am
Additional question, do I also have to recompile gr-osmosdr?
Sasan
Postby Sasan » Thu Jul 19, 2018 12:02 pm
gr-osmosdr has nothing to do with SoapySDR.
Make sure that your device is detected by the OS first (for example by lsusb)
Then try with CubicSDR or gqrx (although the former relies on Soapy).
I've experienced a weird bug in the past: the first run of SoapySDRUtil did not work and I had to run it for a second time to detect SDRPlay!
DF2HF, NM9A, EP2C
Rebel
Postby Rebel » Thu Jul 19, 2018 1:21 pm
It's getting strange now for me...
SoapySDRUtil --probe shows:
libusb: error [udev_hotplug_event] ignoring udev action bind
libusb: error [udev_hotplug_event] ignoring udev action bind[/color]
-- Device identification
driver=SDRplay
hardware=1605056300
mir_sdr_api_version=2.130000
mir_sdr_hw_version=2
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
* ExtRef Enable - External Reference Control
[key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Antennas: Antenna A, Antenna B, Hi-Z
Corrections: DC removal
Full gain range: [0, 47] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 8] dB
CORR freq range: MHz
Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
Sasan
Postby Sasan » Thu Jul 19, 2018 1:36 pm
Have you installed the udev permission rules?!
Look at the page 4 of http://sdrplay.com/docs/Mirics_SDR_API_ ... e_r1p1.pdf
EDIT: I use SDRPlay on OS X, not Linux, but found this on the forum (search for udev)
DF2HF, NM9A, EP2C
Rebel
Postby Rebel » Fri Jul 20, 2018 7:36 am
Thanks a lot Sasan for your hints... udev permission rules were and are in place, have checked again to be shure.
Looks like I ran into the same issue you've mentioned, first run of SoapySDRUtil does not work, after trying second or third time I have the expected output:
fred@amazona:~$ SoapySDRUtil --probe
Probe device
driver=SDRplay
hardware=1605056300
but still CubicSDR and GQRX do not see the RSP2, btw. RTL Stick is working fine.
I woud like to try to go back to 2.11 of the RSP_SDRPlay_API_Linux, but can't find this file anymore. Have no other ideas at the moment and no clue what to do.
73s de Fred, DL6BAW
Sasan
Postby Sasan » Fri Jul 20, 2018 9:02 am
It's hard to say, but my gut feeling is that you have a problem with Soapy, not the API driver.
Have you tried "soapy=0,driver=sdrplay" in Gqrx?
Are you sure you don't have multiple versions of Soapy installed?
Have you tried the "Refresh" button in CubicSDR's device dialog?
DF2HF, NM9A, EP2C
Users browsing this forum: Bing [Bot] and 6 guests
