rsp2 with Diamond vx30 troubleshooting
athenian
Postby athenian » Mon Feb 25, 2019 2:01 pm
Hello everyone,
I recently got an rsp2 and using Diamond VX30 for an antenna. The product description is:
"Diamond VX-30 144/430MHz(2m/70cm) Gain:2.15dBi(144MHz),5.5dBi(430MHz) / Max. power rating:150W (Total) / Impedance:50ohms VSWR:Less than 1.5:1/ Length:1.3m / Weight:0.7kg / Rated wind velocity:60m/sec.Mast diameter accepted:30mm to 62mm / connector "
I mainly want to use the combo for satellite tracking and although I have tried several settings with different software ie SDRuno, sdr console, hdsdr (EXTIO), it seems I can't to get proper NOAA signal. The antenna is placed on top of my house and I've reached a point where I need the community's input in order to solve this issue. What am I doing wrong?
Thank you
Users browsing this forum: bindup and 6 guests
